Lm317
I found a LM317 regulator in an odd bag from Radio Shack in my house. I love the thing but it gets incredibly hot and I even have a heat sink on it. I want to know if the LM317 from Radio Shack has thermal overload protection and/or current overload protection. Or is it okay to let this IC run hot?
What are the input and output voltages, and what is the output current?
You need a *much* larger heat sink, or forget about the LM317 and use a switcher.
edit: Yes, two in series (not parallel) would work It doesn't increase the amount of current you can pull, but it splits the power dissipation.
Here is a video tutorial on the basics:
EEVblog Linear and Switchmode Power Supply Tutorial
It's a pre-built module. You don't have to buy any discrete components. (Be sure to check the datasheet to make sure the specs meet your requirements.)
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=102-1713-ND
Would this product really work at 31V and 500 mA without any external heat sink?
I would probably use the 317 to pre-regulate down to around 28 volts (or a few of your diodes) and go for it.
But like Leon said, a more suitable power supply is the best way to go.
Also check Jameco. They have a lot of inexpensive power supplies that would meet your requirements.
