Resistor rule of thumb?
I've read somewhere that the rule of thumb for resistors is to use half or less of the wattage it is rated for if you are using the resistor for extended duration. Is this true? I am planning on getting a 10W wire wound resistor and powering it around 8 watts, will the resistor be o.k.?
That said, your 10W resistor will run hot at 8W and the heat will affect components around it. You'll need some way to get rid of the excess heat like ventilation.
