Scan a set of arrays faster
Hi everyone,
First off, thanks for helping me out with compacting the size of my Prism guitar code. In the end, reducing the size of the Karplus-Strong buffers made the biggest difference, though moving all the strings to the upper memory locations in EEPROM made a big difference, too.
I'm now working on the algorithm that measures the player's finger position along the frets, and returns an offset that can be added to the "open" tuning of the string to play a new pitch.
A different program is used to load in fret thresholds into memory (String0Frets -> String3Frets). When the memory checker program (and eventually, the main program) is run, those values are loaded into a local array. Inside a loop, the current position of the player's finger is continually read from the ADC. A "repeat until" loop is then used to compare that value to each indexed value in the relevant array, until the indexed item is larger than the measurement. The value of the index pointer is then set as the offset. This is done for each of the four strings.
This works well enough, but I'm wondering if there's a faster way to do it. The reason is that it takes a while for the index value for any one string to return back to zero (no offset) when the player's finger is removed from the string. Maybe half a second or so? On an ordinary guitar there is almost zero transition time so I want to replicate that as well as possible. Of course, it could be the ADC or the hardware anti-aliasing filter I'm using, so there may be no software fix.
Anyway, code is attached below in both 12blocks and ordinary spin. There probably isn't much use in compiling it since you won't have the same hardware as me, but take a look at the logic and let me know what you think...
The basic idea is that you start in the middle and depending on the compare result you go up or down or you found the right value. The distance of going up/down is initially 1/4 of the size of the array. With each iteration you'd divide the distance by 2.
In the plain loop-search you need 16 comparisons in average. Minimum 1, maximum 32 comparisons.
With binary search your min. is 1 and your max. is 5 to search for equal - propably one more to search for > instead.
Unfortunately from a non-music person with limited analog experience, I cannot help you in this. However, it would seem to me that there should be a software solution to reduce the decay time significantly, unless the resistor-capacitance time constant is too large in hardware to allow fast decay rates. Perhaps it would help others to comment further if you posted the ADC section of the schematic.
So, here's some pseudo-code for a non-if-then-else solution based on a loop:
idx := 15 delta := 8 repeat until (array[idx] => adc) and (array[idx-1] < adc) if array[idx]>adc idx -= delta else idx += delta delta >>= 1The comparison to array[idx-1] has been added due to the fact that you don't really do a binary search, which would check for equal. But this also includes a little problem: if the right value would be in array[0] your idx would actually reach 0 in the end which gives you an access to array[0 - 1] which is out of your array. But you can propably solve this by yourself, right?! ;o) You can either extend the condition of the repeat (which is slower) or extend the array and change the start-index.
But yes, it's true, I'm not looking for an exact match. Since the player's finger can be anywhere within the fret, and the value returned by the ADC will be within a range, I'm using the fret (the metal strips on the fretboard) as the threshold. Thus the use of fret0<getString0Frets(x). It looks for the first case where the array item is greater than the value, then exits the loop. My array is actually 19 elements (0 to 18) which makes thing a bit less tidy when it comes to dividing. That's why I did it using if-else statements before. I'll see how I can incorporate the bit-shifting into my code...
Instead of "_bsl.pause(200)" at the beginning of your inner loop why not wait until a string is not pressed.
FretCapture := 0 repeat until FretCapture > 0 FretCapture :=_ adc.getval(1)
