Gigaware usb to serial adapter for bs1
Trying to communicate with my bs1 but no joy. I have read there is a problem with usb to serial adapters is the Gigaware one. If I continue to click on refresh in the info window I can get the info to appear once in a while. But no commo. I don't have a serial port on my laptop. My bs2 with b of edu works fine but it is a usb board. Checked pin voltages look good on bs1. Using 9 volt battery. Any suggestions? If it is the adapter is there a way to change the config to make it work?
