BST does not open files from folders with special characters like
I would like to use bst as it has a serial terminal that connects automatically between compiling
I just unzipped the bst.exe and started it.
Then I tried to open a *.spin-file from the main menu file open -choosing a file and click ok
but the file is not loaded.
If a do a double-click on a file that is listed in the tab on the left the file gets opened.
For somebody who is new to the propeller this behaviour "not opening a file" is a reason to
"throw it in the trash-can-reason"
To be honest this is one of the very few cases that I get upset. Opening a file from the main-menu is
one of the most basic things that a program should be able to do - reliably independent of
configuration.
Is this a known issue?
Do I have to adjust some options to make it work?
I'm using windows 7 ultimate.
best regards
Stefan
configuration.
best regards
Stefan
Been using BST a long time and never heard of such a problem.
How are your file permissions?
filepermission is full access
I don't think it is a problem with the filepermission. If I doubleclick on any file it is opened.
and if I don't know enough on how to change it (except clicking on properties of the folder and check on full access)
no other software had any problems with open or close files. Even software like audacity, isobuster ultraedit that where NOT installed but only copied to a folder
can open and save files.
another problem Occured if I try to save a file I get an errormessage can't save file C:\\....
So maybe bst tries to load from a path C:\\ wich of course does not exist.
I think here the problem is the double-slash instead of a single flash
I guess bst.exe uses different Windows API-functions to open/save files. But here I'm lost. My knowledge ends at "windows is bloated with OS-API-functions"
best regards
Stefan
Apart from trying it on a different machine/OS I don't know what to suggest.
In fact, the optimizer produced about a 10% savings in code size over prop tool. Probably due to dead code elimination. This might be handy for those problems where I start to walk close to the line on space requirements.
Only issue I had was it picking a bizzarely-large and ugly font on startup. I changed it to Courrier New and it looked much better.
What location did you place the executable in when you unzipped it? Windows has been known to do some weird things with virtual folders and paths at times, maybe something that could cause the program grief getting it's current directory. BST does seem to store the last known directory somewhere (it remembers where I opened my last spin project), although I don't know where it stores this information. A quick registry search didn't reveal it, nor do any INI files seems to have been created in the usual places.
Win 7 Pro. I've not done anything prop related on this machine yet. Actually, I've not done much besides run some virtual machines, and some CAD software. My old thinkpad is the Prop machine full time now. It runs BST perfectly as well, and it has prop tool, USB drivers, and video capture, etc... Been propping on that one for years. It runs Win 7 Pro, and it also runs XP, which is what it's running now, because it's been taken out of work service, I prefer XP.
Anyway... I put BST on the desktop, and tried a drag and drop. Spin file, onto BST.exe. worked, but I did get the "publisher not verified" dialog, which is standard for this OS. Opened BST, and did another drag 'n drop, which sort of worked. Got access violation, but I could ignore and proceed. Probably a minor bug there.
Finally, file open, nav to file, also on Desktop, worked just fine.
Here's my environment: I didn't trim it, so you will see some stuff. Compare your user environment on those things that are common. Maybe something there.
Do you have user account control turned on, or off. Do you have the setting where publisher cannot be verified software is blocked?
I would turn both of those off, but do be aware that turning off UAC does leave the machine more open to nefarious software.
Try the "run as administrator" option you will find for BST on the right click menu. Also "compatability options" is not a bad idea.
Actually, before you do any of that, try creating a new user, log on, put a file on the desktop, and bst, and repeat what I did. Permissions will be good on the desktop. If that works, something about your particular user environment is at issue. If both work, but only on the desktop, then you've got a permission problem.
(and yes, I'm ticked about the hostname this machine will very soon be known as "osgood"
thank you very much for your suggestions.
I tried compatibilty mode and "run as admin" but this did not help.
I think it is a problem of permissions. Most of my spin-files are in a folder C:\Windows.old\Users\stefan\Downloads\Software\_Propeller-downloads\000__users
In earlier times my notebook had vista
When installing win 7 ultimate the vista system-folder got renamed to windows.old. But I guess some restrictions on use stayed there.
The strange thing is that opening files from subfolders of C:\Windows.old\Users\stefan\Downloads\Software\_Propeller-downloads\000__users
with software like UltraEdit, Notepad etc. is no problem and saving is no problem too.
If I open files from a more usual folder like c:\temp it works. So maybe it has to do with the path-length.
What is still annoying me is that the choose folder dialogs don't have a textinputfield.
I'm used to type a part of the filename in the tool everything.exe example "cnc spin"
everything filters my 750.000 files on the harddisk in 0,1 seconds down to the five files containing "cnc spin"
right-click and choose open with...
This is much faster than clicking from subfolder to subfolder to subfolder to ...
Now I have a different problem. The font looks strange and seems not to be the parallax-font. And there is lot's of space between each character.
How do I adjust that?
best regards
Stefan
I believe that's some artifact of the upgrade, where permission bits for system objects that no longer exist are there. Some API calls are smarter than others about this... Some of them read the stated permissions and fail, even when EFFECTIVE permissions would allow the action. Have seen this many, many times before, and funny, I see it most often on enterprise software, where I am convinced that the word "enterprise" means crappy!
Not much to be done about the lack of the filter. Either a tool runs with the MFC, or not, and if not, probably doesn't have that particular feature. I use it too, when I can get it; otherwise, I'll create a few shortcuts, filter with explorer and double click. Once you've done that a little, it's just as fast, if not faster than the file open deal. YMMV, but maybe that gets you to a happy place!
You have the parallax font right?
I've noted the characters render a bit differently. I think this is due to a whole lot of things. Here are two screen captures from my newly built reference system. This one is plain vanilla, XP, latest Prop Tool, Latest BST, Parallax Font, and USB drivers. Everything is default, "out of the box" BST does not use bold for some syntax highlighting where the Prop Tool does. Other differences are gonna come down to the renderer Brad used. I find I like it after a time, returning to the Prop Tool leaves me the impression of "thick" fonts, and the reverse happens when I'm using Prop Tool a lot.
If you see what I see, I think that's normal.
Hmmm... Well, enjoy the nice hills of Scotland. I'll leave the attachment mistake.
Shown on the dialog, I've also picked the two check box options at bottom.
That's probably as good as it gets, unless you go and select some other font.
the folder contains special characters like
