Encoder wheel interpertation
Just so we're on the same page I'm a begginer at programing.
I have a encoder from USdigital (an E2) and I am trying to create a program that will count the marks on the encoder wheel.
I want it to count up when I turn the motor one way and count down when I turn the motor the other way. I don't care which way is up or down just so long as it is accurate.
The encoder wheel has three outputs pin 0 has the index it shows up once a rotation. Pin 1 has channel A and Pin 2 has Channel B
Channel A and B (or pin 1 and 2) work in this way. when turned clockwise Channel B leads Channel A and when turned counter clockwise Channel A leads B.
The wave looks like this when turned counter clockwise
A..
................ High.........(I had to use the periods so that everything would show
B.......
........... High.................up the way I wanted it to. Sorry)
A............
........Low
B..
..Low
I use the index to start the program at the same location of the motor
I use the Space where both A and B are High for a refferance point.
So I wait till they are both High Then at that point I wait for A or B to go low which would indicate which direction the motor is turning.
If A goes low first then count Up in increments of 1
If B goes low first then count Down in increments of 1
Now that I have explained What I am trying to do NOW THE PROBLEM
Here's my program
Waitpne (|< 0, |< 0, 0)................................(Wait for index)
..Repeat...................................................(Begin counting program)
....Waitpeq (%0110, %0110, 0)...................(Wait for pin 1 and 2 to both be High, aka refferance point)
....if ina[1]~...............................................(If pin 1 goes low first count up)
.......count := count + 1
.......Waitpeq (%0000, %0100, 0)................(Wait for pin 2 to go low so that I only get one pass through the loop
or one increment per Channel A mark)
....if ina[2]~...............................................(Same as above except count down and wait for pin 1 to go low so as
.......count := count - 1.............................................to get only one increment each time through loop without this
.......Waitpeq (%0000, %0010, 0)..............................it counts super fast because the loop is so fast)
WHATS NOT WORKING is that if the "if ina[1]" statements are the only ones that get exicuted. But if I copy and paste the "if ina[2]" statement above the "if ina[1]" statement then it is the only one that gets exicuted
Other then that it works perfect ( I still have to build a reset so that once it reaches 720 or -720(one rotation) the count resets but that is for another time after I get the counter working. it should be easy anyway)
Why I thought this would work is because I thought the repeat command would be constantly checking for one of the if statements to be true and then exicute the first on that becomes true. I guess not
What can I do to make the propellors logic perform
if A and then B occur then do this but
if B and then A occur then do this other thing.
Well that's the best I can discribe the problem I have and why I am Stuck.
Any Help to get me past this hurdle would be apprecated.
Thanks.
A..
B.......
A............
........Low
B..
..Low
Here's my program
Thanks.
So for now in order to check a pin for high use if ina[pin] checking for low would be ifnot ina[pin].
I assume you want to get there by yourself rather than use an existing object?
Second I do want to get there myself. But being a beginer I would like to have access to another object that does work with an encoder doing more or less the same thing I am, so I have something to look at when I get stuck again. for ideas.
Third If any one has an idea about this but
I want this motor to spin at about 10_000 RPM. With my encoder counting 720 times a revoultion and how I am getting my program to run will I be able to spin it this fast?
I know the prop is fast (boggles my mind fast) but that is a lot to do in a tiny bit of time?
Thanks Again for your help
John Abshier
You can use the Quadrature Encoder or the Dual Quadrature Encoder Driver in the OBEX
So I racked my head some more I figured it out. What was happining was that the code was going to fast through the repeat loop. More or less how I had the code both the refferance point that I made and what I was thinking was waiting for the next step simple was instead checking if my "if ina[A]" statment was true and then repeating again.
How I fixed it.
So in my first post I asked how could you get the propellor to understand if A and then B happened do one thing but if B and then A happened then do a different thing.
Well you use a nested repeat loop inside the other loop that would quit when something occurs. the First repeat represent waiting for A and the second repeat represents waiting for B. Like this
example.
Repeat
if ina[1]
repeat
if ina[2]
count := count + 1
quit
if ina[3]
count := count - 1
quit
That is not exactly how my code looks that that is the logic I used and it worked great.
Anyway just an update on how I'm doing on my little project. and another thanks for the comments
take care
I don't quite follow your logic here- It looks to me like you are monitoring 3 inputs? ina[1] ina[2] & ina[3] is that correct? Would you mind posting part of your code that deals with this?
Thanks.
