LED predictions
LEDS will account of 50% of general purpose lighting by 2016 and prices will drop 90% in four years.
http://www.electronicsweekly.com/Articles/2011/06/17/51289/led-prices-to-fall-90-by-2015.htm
Time for companies to start thinking about renegotiating pricing and playing hardball by telling vendors "Is that the best you can do?" and "I'm putting it out for bids."
I prefer incandescents myself. They keep the chicks warm on cold spring nights and the pump house from freezing on cold winter nights.
LED's were only recently made as energy efficient as flourescents, and there are significant technical problems beyond just making the LED's, such as heat dissipation (since the actual light producing elements are so small). There is also the significant matter, once you know how to do everything, of expanding production capacity enough to fulfill the market demand you're creating. Expecting a startup technology to take 50% market share from not one but two entrenched competing technologies in only 4 years seems more than a little unrealistic. It took considerably longer than that for flat-panel TV's to completely displace CRT's even when there was a clear technical path to making them cheaply, and part of the reason was ramping up the manufacturing for big LCD panels. I expect LED lighting to face a similar introductory period; even if they figure out how to make the chips for nothing tomorrow, they will have to build manufacturing and assembly plants, create mounting standards, and all of the other stuff that was done long ago for conventional lighting. Tight supply will keep prices high (and the profits will be funding the expansion) while this is all sorted out.
I might believe 50% by 2021.
I'd spot you on that too because there isn't any other tech out there with quite the possibility. White LED's were a holy grail for the electronics industry since I was a kid, and I'm talking the 1970's there. (Actually the holy grail was blue LED's, which people thought would then make white through R+G+B and LED color TV instead of CRT's. When it happened, it was actually ultraviolet LED's and they use flourescent phosphors to convert the UV to full spectrum white light.) It took 40 years from the dawning realization that a solid state light source might be possible for it to become practical for white-color area illumination.
I don't see any other tech for illumination that is in the place today that LED's were in 1970. I do think that eventually (but not within 4 years) the advantages of totally solid state manufacture will start to make themselves felt enough to put a dent in both the incandescent and flourescent markets. Then those will be the target of choice for the next potential better candidate, which probably doesn't even exist in a laboratory yet.
I also bought a Philips 60W equiv AmbientLED dimmable bulb from HomeDepot but at $40, they are too pricey. They do provide more light toward the base. Even though the "bulb" is yellow, it is white when lit.
