Voltage regulator on Xbee SIP Adapter
I'm totally new to electronics, so forgive me if this is some obviously elementary question. I have purchased an XBee adapter which has a 5 to 3.3V voltage regulator for voltage input. Does this mean I can provide voltage anywhere between 3.3 to 5V? Or must I provide a 5V voltage? (e.g. Can I provide a 4.5V voltage to the adapter with three 1.5V battery?
The data sheet for the XBee adapter can be found here:
http://www.parallax.com/Portals/0/Downloads/docs/prod/rf/32402-XBeeSIPadapter-v1.1.pdf
Voltage regulators have a minimum voltage drop (called the "drop out" voltage). The regulator used on this adapter has a drop out voltage of around 0.5V. That means that you can use power supply voltages down to 3.8V and still get a regulated 3.3V output. So, yes, you could use 3 x 1.5V AA batteries to run it.
