How to design custom fonts for Propeller — Parallax Forums
william chanwilliam chan Posts: 1,326
edited 2011-06-17 07:02 in Propeller 1
I am trying to display large fonts on VGA, but the ROM fonts are too small.
Is there an easy way or tools to help design large fonts?
Thanks.
  • max72max72 Posts: 1,155
    edited 2011-06-17 02:58
    If you use graphics.spin you can scale it up.
    Massimo
  • RaymanRayman Posts: 16,273
    edited 2011-06-17 06:06
    I've got a 1-bit graphics tool on my website. I'm not sure you'd have enough memory to implement a full, larger font though...
    Actually, doesn't the VGA driver have hx and vx horizontal and vertical expansion like the TV driver?
    Maybe you could try specifying 1/2 the tiles in both x and y and see if you double the size of the font on the screen...
  • nestor73nestor73 Posts: 33
    I'm dealing with the same problem. I needed text and 2 big clocks on the VGA screen. I ended up building the clock characters with empty strings in an array for each number :-)
