32 AWG Magnet wire for SMT components???
I don't have any thin wire for connections on a SMT component, I only have Magnet wire at 32AWG, is it safe to use that as a substitute?
It will be used on an I2C expander inside of a "HO Slot Car" (1975 ThunderJet Chassis) directly above an 18Volt motor, and will control vehicle lighting and motor speed.
I would assume that it would pickup noise from the motor.... but I have plans to use some scrapped RFI sheilding from an old Monitor between the motor and circuit.
"Magnet Wire" really does not have any magnetic properties unless it is wound on a coil. It's just wire. Trying to strip the lacquer of is the hardest part. You can try and scrape it off, but the easiest way is to burn it off with a lighter. I just did 46 connections using this method with green magnet wire that connected to LED's hidden in green foliage.
BTW, here's a hint for stripping short pieces of wire-wrap wire:
2. When you need a piece with, say, 3/4" of insulation, begin to strip that much off.
3. When the insulation gets near the end of the wire, stop, leaving just enough bare wire to make the connection.
4. Clip the wire to length.
5. Once the bare end on the spool gets short, strip off another inch.
I used to clip the wire after stripping just enough off the first end, then hold the short piece in my teeth to strip the other end. 'Took years to figure out the better way. D'oh!
30 GA Wire Wrap wire is available at Radio Shack.
http://www.radioshack.com/product/index.jsp?productId=2062642&numProdsPerPage=60
My suggestion was only if the OP needed to effect a repair or build at the moment. It is good to have 30 Ga Kynar on hand at all times.
Dipping the wire end to be soldered in nail polish remover and wiping it with cloth or paper towel works.
Thanks for the replies, just want the info as to whether the magnet wire shouldn't be used.
They don't sell this any more but you can make your own:
http://www.instructables.com/id/Wiring-Pen/
-Katie
