Serial Syntax Question: What is this doing?
I don't understand what my code is doing; the result is unexpected in my eyes.
I'm reading serial bytes on my propeller using JDCogSerial (http://obex.parallax.com/objects/398/) and this command:
If I send $FF, the firmware will run the code inside the "if" (but I don't want it to). I need it to only perform the code inside when a byte is received. I'm assuming that $FF can also be -1 and this is causing the problem?
Here's the rxCheck function definition:
Is there a way to check if a byte is received, and if so do something with it (even if it is 255)?
My code runs fine if I make sure I don't send a byte value of 255 (I cap everything at 254).
recByte = Comm.rxCheck
if (recByte <> -1)
... do something
PUB rxcheck : rxbyte
{ Check if byte received (never waits)
returns < 0 if no byte received, $00..$FF if byte }
if (rxbyte := rx1_buf) => 0
rx1_buf := -1
if (recByte <> -1)" Is not $FF - But $FFFFFFFF.
And $FF are still received Character = 255 Decimal.
You need always check for -1 for no received character.
Ps. That give You possibility to receive all characters from 0 to 255
Can you post all your code? rxCheck should be doing the right thing. Maybe there is a problem in how you handle recByte. If you happened to declare recByte as a byte or word it will never contain a value of -1, but will be 255 or 65535 instead.
A value of 255 is as valid as any other 8-bit value. It shouldn't cause your code to do anything differently unless you are testing for 255.
Dave
