Stack connectors
I have seen on the forums many examples of connectors (the usual single line 100mils type) made for PCB stacking.
I searched Mouser and Digikey, but I didn't find a similar prduct. Could you address me to a suitable connector, or the right keyword?
Thanks in advance,
Massimo
Thanks in advance,
Massimo
http://www.rapidonline.com/Cables-Connectors/Connectors-Multipole/PCB-Interconnect/2.54mm-PCB-Interconnection-system/63793
http://www.rapidonline.com/Cables-Connectors/Connectors-Multipole/PCB-Interconnect/Single-row-sockets/76075
Similar ones are available from other suppliers.
http://forums.parallax.com/showthread.php?131321-ppBridge-Propeller-Platform-proto-board-with-10pin-module-support-%28NOW-SHIPPING%29
edit:
There are the PC104 type connectors that explain this:
http://www.pc104.org/images/plus_fig2.gif
Where can I find them? Mouser maybe?
Searching for stackable header or something similar didn't bring any meaningful result..
Massimo
Here is the manufacturers description:
2.54mm FEMALE HEADER DIP STRAIGHT HEIGHT=8.5MM 1X08 DIP=10.5mm
It is the same 0.1" 8 pin header used on Arduino boards. The male pins are 0.394" (10.5mm) long.
Ooops, guess i better raise my price to remain consistent ;-)
I would like to use them with gadget gangster's boards, so 21 would be perfect. Otherwise is it easy to split them in half?
Massimo
Six 8x1 headers can be used with the gadget gangster boards.
Two of the 8x1 header will have to be cut down to 4x1.
I'll look around for easier solutions, but the 8x1 is the best available for now.
PM me if you want any 8x1 headers.
--Steve
