Best way for 8-bit color on 24-bit lcd ? — Parallax Forums
RaymanRayman Posts: 16,402
edited 2011-07-26 13:56 in Propeller 1
I've decided to try to make an 8-bit driver board for my 3.5" touchscreens.
The current driver is 6 bit (2 bits per color). There, it was fairly simple to decide how to best connect the pins, although I needed help...
The answer was like this:
10101010
01010101
Now, I'm getting greedy after figuring out that I don't really need the HS and VS sync signals, giving me two extra bits for color. I've read on wikipedia about some old 8-bit modes...
But, the question is how best to connect the pins... Want evenly spaced color levels. Also, want true gray scale, like before on at least 4 levels...
Anyway, here's my solution. If anybody knows a better way, I'd love to hear it!
For Green and Red:
10010101
01001010
00100000
For Blue:
10110101
01001010
622 x 407 - 7K
  • PerryPerry Posts: 253
    edited 2011-06-13 15:27
    Ray
    You might consider a color difference method of coding.
    If you used 2bits for Red and Blue difference signals, and 4bits for luminance you could get the Green from a 256 byte table.
    that way you could effectively have nearly 4bits per color.
    Perry
  • RaymanRayman Posts: 16,402
    edited 2011-06-13 17:53
    Perry, that sounds great, but I don't see any easy way to physically implement it...
    edited 2011-06-13 17:55
    I did just think of another idea though... Use a second Prop chip as a 24-bit CLUT. Then, I could show a 256-color picture with an arbitrary palette...
    That would raise the cost a bit more that I'd like though...
    edited 2011-06-13 18:14
    I would like to see Eric Balls's greyTV driver used for VGA.
    you probably would need 3cogs synchronized though.
    but there would be much less hardware with 3 dutyDACs driving the VGA RGB pins.
    it would then be possible to do greater color depths with 2byte pixels
    you also might need sample and holds after each dutyDac so you hit the sample enable after all DACs are set.
    OOP's sorry I misunderstood, your driving 24 bits not a VGA interface
    Perry
  • TubularTubular Posts: 4,774
    edited 2011-06-13 18:21
    Ray,
    I think the way you have it is about the best that can be done, giving blue levels at 0, 74, 181, 255.
    The Prop as a CLUT? Interesting idea, wonder whether that could be made to work.
    I was just thinking yesterday at having a look at some old ISA vga boards (Orchid, Tseng Labs, etc), see what chips they used for the lookup table / DAC.
    edited 2011-06-13 18:42
    Tubular, thanks for looking that over.
    I think the CLUT could work for me only because I can drop the pixel clock to 5 MHz or so and still be OK. It seems hard though, now that I think about it...
    Maybe I'll have to look up Beau's Prop-Prop code and see how fast that can go with more pins...
    edited 2011-06-13 19:34
    Yeah the 5 MHz makes it possible and tempting.
    Some of the LCD datasheets I've looked at don't specify a minimum clock. I wonder if that is for real and they can really be run slow, like 1MHz or below, or whether they haven't bothered filling in that box of the datasheet because they assume everyone works at the nominal frequency? Would love to know...
    If you used a second prop as CLUT I'm guessing it would really only tie up one cog, correct? Or I suppose you could split off into colour planes and use 3 cogs if there was some advantage. The other cogs and spare RAM might be good for USB host, etc...
  • daniel dingdaniel ding Posts: 52
    edited 2011-06-13 20:06
    I am a beginner of the propeller chip. Who can tell me if the propeller chip can support more than 16*2 lcd. For one 16*4 or 16*8 lcd! thanks!!
    edited 2011-06-13 20:24
    hi Daniel, and welcome.
    Sure it can drive a 16x4 LCD. Parallax sell this one, and they include example code. This would be a great place to start.
    Rayman here is the expert supplier & coder on some cheap and very popular graphic LCDs that make use of the Prop's ability to display graphics - see his website . Some are cheaper than 16x4 LCDs (!)
    edited 2011-06-13 20:53
    Ray,
    My calculations show that you'd get the best separations for red and green with:
    00100100
    01001001
    10010010
    This yields a suboptimal setting for blue, however, in order to obtain pure grays:
    01101101
    10010010
    with gray values at 0, 109, 146, and 255.
    Just out of curiosity, how did you arrive at your bit codes?
    edited 2011-06-14 00:50
    Hi Tubular
    Thanks for your help while do you mean that I have to use the LCD made by parallax only or anyone else 20x4 LCD. In addition dose it support the Chinese character. Thanks a lot!
    edited 2011-06-14 02:40
    Phil, I got those codes by trial and error with pen and paper...
    My first try was:
    Blue (same as before)
    10101010
    01010101
    Red&Green
    10000000
    01010101
    00101010
    But, I soon figured out that that was a terrible choice...
    daniel, I'm sure you can use any character LCD you want. I'd be surprised if you can't find one with Chinese font, seeing how most of them are probably made in China... But, if you really, can't, I sell a graphical monochrome LCD dipslay at GadgetGangster.com...
    edited 2011-06-14 02:43
    Tubular, well Prop as CLUT was a fun idea, I think I could have done it at 20 MHz even by using 4 cogs...
    But, after second thought, the economics don't support it... Actual plan is to use a Solomon graphics chip, which costs the same, but has a lot more functionality...
  • wjsteelewjsteele Posts: 697
    edited 2011-06-15 07:22
    Rayman wrote: »
    Ray, can you explain how you accomplish this? Is it something we could do with the 4.3" as well? (Just off the top of my head... since it is a fixed timing signal... so could it be that simple... feed the HS of a clock and a VS off the clock*height?)
    Bill
    edited 2011-06-15 10:08
    The 3.5" lcd have two different sync options... One is the regular VGA style with HS and VS. The other way is using DE (data enable) along with the pixel clock.
    Both ways work, but the DE way lets me generate 8-bit color with just 1 cog.
    My 4.3" lcds don't have a DE option. But, perhaps you could do the same thing using 2 syncronized cogs...
    edited 2011-06-15 10:35
    The syncs occur very infrequently compared to the color data. So there's no reason for them to be controlled by the Prop's video circuitry. They could just as easily be assigned to separate pins and timed in software.
    edited 2011-06-15 10:40
    Really? Interesting idea... Has anybody done an 8-bit color VGA driver? I think that'd be pretty nice actually...
    edited 2011-06-15 10:50
    The only catch I can see is if the video PLL frequency is not a multiple or sub-multiple of the system clock frequency. Then you might get some horizontal jitter.
    edited 2011-06-15 11:02
    I did just find a post from Bill Henning about a 256 color VGA mode for Morpheus... I'll have to take a look at that...
    edited 2011-06-15 11:19
    Just looked at Bill's mikronauts.com web site and I see he does do 8-bit color. But, if I'm reading it right, he uses a second cog to drive the sync pins...
    I think it could be done in one cog though, might have to give that a try someday...
    edited 2011-06-15 11:25
    Another approach would be to use the video output for the syncs and to change vcfg during sync time to point to those two pins instead of the color pins.
    edited 2011-06-16 07:20
    Rayman:
    Correct, although I use up to seven cogs depending on the driver and its memory and rendering cog (points, lines, sprites etc) requirements. I can reduce that by 1 or 2 cogs.
    Phil:
    I considered that, but have not had time to experiment with changing vcfg during sync. If the change takes place immediately and does not mess with the PLL, it should work fine...
    Between you guys I ended up adding a new item to my TODO list.
    edited 2011-07-26 12:21
    Finally got a chance to try this 8-bit color mode with the 3.5" touchscreens...
    It works! Now have 8 levels of red and green, keeping 4 levels of blue and 4 grays...
    Here are some photos of the new 8-bit palette:
    748 x 561 - 224K
    748 x 561 - 187K
