very basic question for beginner
I am brand new to microcontrollers and programming. I have the "What's a Microcontroller?" book and am going through it. In the Digital Input - Pushbuttons section (chapter 3) I tested my pushbutton and it appears to work fine, but when I hook it up to the Basic Stamp I cannot get it to function the way it does in the book. The first activity is a very basic setup that is suppose to display in the Debug Terminal the state of the BS2 Input (1 or 0). The code is:
Vdd ---> pushbutton (pb) pin1; pb pin2 ---> 200ohm ---> BS2 P3; pb pin3 ---> 10k ohm ---> Vss.
In theory I'm suppose to see a 1 when the button is pressed and a 0 when not. In actuality, I see a 0 when not pressed and get nothing in the Debug Terminal when it is pressed.
Help would be greatly appreciated.
PAUSE 1000 DO DEBUG ? IN3 PAUSE 250 LOOPThe setup is:
DEBUG "top",CR
If you see that every time you press the button, then the Stamp is resetting.
With the program as given, there is no other way that I can think of that it would show nothing at all when the button is pressed.
