NEW BOE-BOT - Servos Not working
I received a new BOE-BOT last week, and got to ACTIVITY #3 CONNECTING TO SERVO MOTORS, using the instructions for the BOE Rev C, I followed the instructions on pages 42-45. I was using the supplied battery pack with fresh (1.6V) AA batteries. the jumper was set at the Vin position as stated on page 43. When attempting ACTIVITY #4 Centering the Servos - I get no response from the either servo, it doesn't matter which servo, using P12 or P13, The LEDs are set-up on the breadboard as the instructions indicate. I get the expected output on the LED, but absolutely nothing from the servos.
I have tried each servo, in each of the P12 and P13 sockets.
What advice do you have?
If you have a digital multi-meter you could check the voltage of the center servo header pin to ground and make sure it is around six volts. It likely will be, but I always check voltage when something doesn't work as expected.
I checked the wires - they're oriented correctly, but I didn't have small leads for my home DMM. I'll check the voltage when I get home.
I'm heading home in a few. I'll check the output on the servo socket.
Rich H
Uh, actually, there is not. You are really workin' towards that fifth start aren't ya?
Rich H
Erco, the fourth position switch is only on those boards with the revision number 1.41421356.
-- Gordon
