wiz811mj + prop as spinneret equivalent?
Has anybody used a wiz811mj with a prop to make a spinneret equivalent?
http://www.wiznet.co.kr/Sub_Modules/en/product/Product_Detail.asp?cate1=5&cate2=42&cate3=0&pid=1030
I had purchased a wiz811mj before the spinnerets were available, now I want to use it as a spare for hacking.
I compared the spinneret schematic to the wiz811mj datasheet, I think its:
Prop -- WIZ811mj
p0 -- D0 J1:4 and MISO J1:2
P1 -- D1 J1:3 and MOSI J1:1
P2 -- D2 J1:6 and /SCS J2:4
P3 -- D3 J1:5 and SCLK J2:3
P4 -- D4 J1:8
P5 -- D5 J1:7
P6 -- D6 J1:10
P7 -- D7 J1:9
P8 -- DATA0 J2:11
P9 -- DATA1 J2:12
P10 -- /WR J2:5
P11 -- /RD J2:6
P12 -- /CS J2:7
P13 -- /INT J2:8
P14 -- /RESET J2:2
P15 is listed on the spinneret schematic as going to SEN on the W5100, but I didn't figure out how to make the connection.
And power 3.3v and ground of course.
I connected everything as shown, but this isn't working. My test software works fine on an actual spinneret, so I'm pretty sure I didn't connect the hardware properly.
Since I want to leave SEN high and use parallel mode, can I leave P15 unconnected?
Can P0-P3 be connect to two pins on the WIZ811mj as shown?
Or did I cook my parts already?
EDIT: Also A2-A14 are left unconnected. Do these have to be pulled low?
Prop -- WIZ811mj
P4 -- D4 J1:8
P5 -- D5 J1:7
P6 -- D6 J1:10
P7 -- D7 J1:9
P8 -- DATA0 J2:11
P9 -- DATA1 J2:12
P10 -- /WR J2:5
P11 -- /RD J2:6
P12 -- /CS J2:7
P13 -- /INT J2:8
P14 -- /RESET J2:2
http://forums.parallax.com/showthread.php?131489-Anyone-using-INDIRECT-drivers-for-WIZnet-module-not-part-of-the-Spinneret
Also by PM
This is a good thing to check. However, I am using the propforth implementation, which does not use the Indirect Driver.
Propforth is already demonstrated to work on the spinneret hardware. Therefore, I'm thinking that if the wiz to protoboard connections are equivalent the spinneret connections, I have the proper connections, and proper software.
If all this is a correct, I made an error in sloppy wiring. Since I don't need anything like power capacitors or current limiting resistors, I'll just tear it apart and wire it again, maybe I'll get it right this time.
Since SEN and /SCS are tied together on the WIZ811/812, I think you need to drive them from P15 and not from a pin that's shared with a data pin. If you're not using the indirect driver then I would be inclined to only connect the signals needed for SPI.
I use the prop/wiz812 combination in serial mode wired as follows:
J1 1,2 to prop i/o pins (MOSI,MISO)
J1 3-10 NC
J1 11,13-19 GND
J1 12 +V
J1 20 NC
J2 1 +V
J2 2-4 to prop I/O pins (/RESET,CLK,SCS)
J2 5-7 +V
J2 8 NC
J2 9-10 NC
J2 11-18,20 GND
J2 19 NC
So basically just 5 i/o lines to prop.
