Would you use the Propeller to simulate a neuron? — Parallax Forums
RsadeikaRsadeika Posts: 3,859
edited 2011-06-13 10:48 in General Discussion
Every couple of years or so, it seems like the topic of AI comes up. We have a couple of threads dealing with neuronal arrays, and/or other configurations. My question is, is the Propeller really suited for this job? Maybe we should stick to the intended purpose of the chip, an intermediary for a sensor attachment.
I did not want to disrupt the other threads, I think their are a lot of opinions about this subject. So, lets share the ideas here.
Ray
  • bill190bill190 Posts: 769
    edited 2011-06-12 07:20
    Well it is not just "a" neuron...
    From the following link...
    ["The [URL="http://en.wikipedia.org/wiki/Human_brain"]human brain[/URL] has a huge number of synapses. Each of the 1011 (one hundred billion) neurons has on average 7,000 synaptic connections to other neurons. It has been estimated that the brain of a three-year-old child has about 1015 synapses (1 quadrillion)."]
    http://en.wikipedia.org/wiki/Neuron
    Then from the next link...
    ["The processing power of average [URL="http://library.thinkquest.org/C001501/the_saga/compare.htm"]human brain [/URL]is about 100 million MIPS. (MIPS -Million computer Instructions Per Second) it means it can handle the process, which a 1640 GHz Pentium computer can handle...
    ...Since the human brain have 100-trillion-synapses, and each synapses can handle one MB of data, the human brain can store 100 million Megabytes of data..."]
    http://mi-programacion.co.cc/processing-power-and-speed-human-brain-vs-computer
  • RsadeikaRsadeika Posts: 3,859
    edited 2011-06-12 08:12
    "Well it is not just "a" neuron... " But, the question is about a neuron.
    The typical response has always been to quote the statistics about the brain, and it's synapses. So, lets see if I divide 7 (cores) into a hundred billion, how many Propeller chips will I need? I think that at this point Parallax is salivating profusely.
    I still have not seen any thread that would deal with just that one lonely neuron. But then may be we should deal with an astrocyte first, before moving to the neuron?
    Ray
  • Mike GMike G Posts: 2,702
    edited 2011-06-12 08:55
    Architecture is the vision of the developer.
    I find that the Propeller is much more than an intermediary for a sensor attachment. My Spinneret Web Server project does not contain a single sensor.
    edited 2011-06-12 09:03
    In the context of the question, I wanted to keep it simple, and probably a sensor of some type is an appropriate device. I guess at some point we will have to get the answer narrowed down to the question that was asked.
    Ray
  • LeonLeon Posts: 7,620
    edited 2011-06-12 09:07
    A typical ANN used for pattern recognition uses a multi-layer feed-forward Perceptron with at least three layers (one input layer, one output layer and at least one hidden layer), and is generally implemented on a single fast processor with fast RAM. The Propeller doesn't seem to be particularly suitable. Other ANN architectures are used, depending on the problem, but none of them seem to suit the Propeller, either.
  • John A. ZoidbergJohn A. Zoidberg Posts: 514
    edited 2011-06-12 09:21
    I believe there is a common issue in ANN - the training part.
    Been working with some machine vision - pretty difficult I would say.
    And also, ANN is 2D. I don't know much about 3D representation, however some of the researchers had been doing that already.
    edited 2011-06-12 09:23
    In the context of the question... architecture is up to the developer. One neuron, sure. An ANN probably not well suited for the Propeller.
    edited 2011-06-12 09:27
    Here is a nice ANN application for identifying faces from digital images:
    http://www.cs.cmu.edu/afs/cs.cmu.edu/usr/mitchell/ftp/faces.html
    I compiled the code without any problems using gcc (Cygwin), but haven't tried it on the supplied images. I need to read the documentation.
    edited 2011-06-12 09:30
    Leon wrote: »
    I compiled the code without any problems using gcc, but haven't tried it on the supplied images. I need to read the documentation.
    A combination of ANN with other AI-based algorithms are done too, like Gabor and SVM (Support Vector Machines).
    The Viola-Jones algorithm seems to detect faces quite fast, uses integral image processing (and some other algorithms inside as well) and only involves addition/subtraction, but some modification must be done on higher-resolution images to cut down on the false-positives. OpenCV has onboard functions which does that nicely.
  • jazzedjazzed Posts: 11,803
    edited 2011-06-12 09:55
    The Propeller chip is not the best choice for *any* huge single application. Modern, Multi-GHz, Multi-core CPUs like on my desktop are much better for such things.
    The attempt to use Propeller to simulate neurons requires splitting the task in a distributed manner. This has not been the path of neural network development because it *didn't have to be* the path. People and things tend to follow the "path of least resistance."
    There is value in the attempting to simulate neurons on Propeller because of things that can be realized along the way and it *may produce* some usable results. I personally have many, many, other more useful things to do. And my time will be spent in productive ways which means neural networks will not be my highest priority.
    The thing is, you have people here who honestly believe the Propeller can be a "Brain" and have been convinced of this by a vapor ware advertisement practicing propaganda machine .... I personally think it's stupid to believe that any combination of Propellers can behave like a "Brain" other than running programs created by people with brains inclined to write programs.
    There is nothing wrong with exploring. However, expectations, prognostication, and vapor should be modest until there is some proof otherwise.
    If anyone wants to help in productive ways other than being some propaganda machine, I welcome it.
    edited 2011-06-12 10:33
    Rsadeika wrote: »
    Ray
    In general two approaches to simulating neurons have been used.
    1 - Build an electronic circuit that mimics neuron behavior.
    2 - Use software running on a fast computer (or cluster of computers) as Leon mentioned.
    Option 1 has been tried but has been generally dropped in favor of 2 due to the high cost and complexity.
    Leon has stated in this thread that:
    "A typical ANN used for pattern recognition uses a multi-layer feed-forward Perceptron with at least three layers (one input layer, one output layer and at least one hidden layer), and is generally implemented on a single fast processor with fast RAM. The Propeller doesn't seem to be particularly suitable."
    While his assertion that the prop is not particularly suitable may be true, I am not so sure of that.
    The folks on this forum have done some pretty amazing things with the prop. Using PASM for neuron simulator code that runs in parallel on individual cogs and uses hub memory for connection tables could prove to be a viable proposition. The best way to find out is to build it, write the code, and go through the usual rounds of improvements.
    Personally I think the prop has a lot going for it for this application.
    1 - Eight independent cpu's
    2 - Very flexible I/O
    3 - Shared hub memory accessible by all cogs on the chip
    4 - Very simple hardware for a board with an array of props.
    While the limited memory of the prop is a disadvantage that disadvantage is not as great as it seems, particularly for this application. The only way to be sure is to build it and find out.
    edited 2011-06-12 12:31
    I think everybody can agree that the neuron has four main characteristics.
    1. Communicate with another neuron.
    2. Communicate with other sensors.
    3. Hold data.
    4. When in an array, has a learning capability.
    So, how would the Propeller fit the situation. Basically the Propeller has eight cogs, and 32 i/o pins. I will address each point mentioned for the neuron.
    1. Inter-neuronal communication. I believe Beau did some experiments with communicating two Propellers. If I remember correctly he something set up where he had it up to 20Mbs, which is not to shabby. So, the networking part, in a very general format, is doable.
    2. Sensor communication. This is a no brainer, plenty of examples for doing just that.
    3. Data source. I am not sure if I have seen any examples of holding external data in cog or hub memory. This could get a little iffy.
    4. Learning capability. This is the hard one, I have not seen any code, that shows that it would be feasible using a Propeller setup.
    Since most of this usually pertains to the subject of robots, how practical would this be to implement on a robot? In another thread I saw mention of a 64 Propeller array. The Boe-bot sure would look interesting with a tower of 64 proto boards.
    I am all for experimentation, but I have not seen any real functioning implementations. So, somebody give me some real examples of a functioning implementation of a small array of Propellers.
    Ray
    edited 2011-06-12 12:47
    Rsadeika wrote: »
    This is a major goal. Not quite there yet.
    There is some character recognition Spin code that uses a neural network. It is a single Propeller program and there are very few comments in it. It may be hard to digest, but the demo picture looks good.
    http://forums.parallax.com/showthread.php?93467-Character-recognition-project-*finished*&p=643109&viewfull=1#post643109
    edited 2011-06-12 12:53
    That seems to use a single layer, and is very limited. It won't solve the XOR problem, of course; a hidden layer is needed for that.
    edited 2011-06-12 13:04
    Leon wrote: »
    All that was requested was "some examples" ... there will *always* be limits and desires to exceed them.
    edited 2011-06-12 13:22
    Ray wanted some examples of an array of Propeller chips doing something useful. I don't think that I've even seen two Propeller chips used for parallel processing. 30 years ago transputers were being used for systolic arrays, ray tracing. and other parallel processing applications.
    edited 2011-06-12 16:14
    Just because you can't do it or understand - does that mean it can't be done or understood?
    The loud noise in the forest that you didn't hear - does that mean it didn't happen?
    Do you really think there's only one intended purpose for the Propeller chip?
    edited 2011-06-12 17:06
    @ Ray,
    I doubt that would be implemented as a stack of 64 protoboards. If I wanted to do something like that it would be with 4 boards having an array of 4x4 props on it.
    The original discussion started on Humanoido's big brain thread about a week ago, and was transferred to it's own thread four days ago. Don't you think expecting real examples in that short a time frame might be unreasonable?
    @Leon
    Again, don't you think expecting real examples in that short a time frame might be unreasonable? Also, please define what you mean by parallel processing. Do multiple props controlling a CNC count as parallel processing?
    At the time the transputer came along it was a big deal. Very high tech and powerful so a lot of folks jumped on it for parallel processing and communications. By the time the prop came out parallel processing had moved to multiple x86 systems with large memories so the prop has never been considered for such use. No surprise there is not much example software for using arrays of props for parallel processing systems.
    @ All,
    I have no doubt an array of props can be used to perform useful parallel processing. All of the pieces are already in place. All that is left is to assemble them and get them working together.
    edited 2011-06-12 17:14
    I was thinking of MIMD or SIMD parallel processing, not an ordinary embedded application like CNC.
    edited 2011-06-12 20:57
    MIMD is inherent in having multiple chips. Multiple Instruction streams working on Multiple Data only requires communications between the chips to distribute the instructions and data. Numerous projects have already demonstrated inter chip communications.
    SIMD requires communications between the chips to distribute the same set of instructions to all the chips, synchronize the chips, and then distribute the data to each chip. Each of the three individual steps has already been done. All that remains is to put them together.
    edited 2011-06-13 00:59
    Are there any examples of MIMD and SIMD processing using Propellers with streamed data?
    edited 2011-06-13 09:13
    Leon wrote: »
    I am not aware of any examples, however at this point I have to say you are really nit picking. Any micro from the smallest 4 bitter on up that has some form of I/O can be connected together and programmed for both MIMD and SIMD processing. It may be wildly impractical to do so, and the result may be excruciatingly slow, but it can be done.
    edited 2011-06-13 09:22
    I don't think I'm nit-picking; people have been talking about doing parallel processing on the Propeller for over two years.
    edited 2011-06-13 09:32
    Leon makes some good points. But he is begging the question as he often does.
    If Leon was ignored here like over on avrfreaks, he wouldn't have over 5000 posts.
    Something to think about.
    edited 2011-06-13 09:43
    What question am I begging?
    What are the good points I've made, so that I can continue in the same vein?
    I'm not ignored on AVR Freaks. I make a lot of contributions, as I do on other forums, which seem to be appreciated.
    edited 2011-06-13 10:34
    Leon wrote: »
    I disagree with your first point, and as for the second point, once I gave it some thought MIMD has been done on a single prop by every project that uses more than one cog so there is no reason it cannot be done with multiple props. As for SIMD that has also been done on a single prop, the perfect example being the video drivers that use multiple cogs. Again, if it can be done on one prop it can be done on multiple props.
    MIMD processors operate on external data streams, doing things like ray-tracing. Video generated by the hardware on individual Propeller cogs is somewhat different. Moreover, cogs simply don't have enough memory for the sort of applications that are typically implemented on MIMD machines, and lack the communication channels that are used for inter-core data transfer. Such channels operate independently of the processor, using special hardware.
    Where are the arrays of Propellers, doing things that are done with other parallel processing devices?
    Reverting to the topic of this thread, has anyone got any positive things to say about using Propellers for neural net applications? I am reminded of Dr Johnson's famous retort: "Sir, a woman's preaching is like a dog's walking on his hinder legs. It is not done well; but you are surprised to find it done at all."
