Power Advice
Hey All...
Looking to provide longer run time for my 'Bots I picked up a rechargeable 7.2 volt, 2000 mAh Ni-cad battery for kinda cheap. From what I've read, it seems this will work with with the BS2 boards. Can I use it, or other r/c car batteries, with my Propeller boards. Any mods needed?
Thanks for any advice!!!!
Amanda
Amanda
Duane
They last a long time compared to four AA's, Plus they fit in all sorts of places...
-Tommy
Second, is the unregulated voltage supplied to the motors. When using R/C servo motors, 7.2V is just about the upper limit and in some cases in might be better to insert a rectifier diode or two to drop the voltage by .6v or 1.2Vas added margin of safety. I suspect that R/C servo motors were originally targeted for 6VDC use and they do have some internal chips that might be stressed by higher voltages AS they don't have a voltage regulator included internally.
