Considering LM4876 Audio Amp
In my quest to move away from the TDA7052, I've narrowed the search down to a few candidates and currently focusing on the National LM4876.
I'm wondering if anyone has experience with this IC?
I need to produce quality 16-bit, 22khz mono PCM audio through an 8ohm 1W speaker (300hz~20Khz range), which the LM4876 is spec'd to handle @ ~5V. The "AUDIO POWER AMPLIFIER DESIGN" section in the datasheet features examples that are pretty close to my specs with the exception of a lower frequency bandwidth limit (100 vs. 300hz).
The reference schematic indicates only 5 small external components ( I have very little board space), and I *think* the addition of an RC circuit on the input would be all that I need to handle the PWM signal from the Propeller. Am I correct?
Anyone see a reason why this chip wouldn't be ideal for my requirements or have any opinions or insights to offer?
As always, your time is much appreciated.
The input comes directly from a Propeller pin. The LP filtering is accomplished via the additional feedback cap. FYI, this amp does not seem to have excessive power for the S2's one-inch speaker.
Do you know who did by chance? I'd like to understand how, and to what extent, the deltas from this schematic and the datasheet version effect the frequency response.
The datasheet calculations are in reference to the "Typical Application" schematic - right? I'm looking to understand how (if so) the additional cap in the S2 schematic (C38) alters the frequency response.
Excellent. Much appreciated...
