lcd display help
I have a 4x16 lcd display that I got to display the "Hello, this is the LCD demo." text using the code from parallax. but now i want it to display a variable now. Also this variable constantly changes so I don't believe i can write it to the eeprom. Any help on how to display my variable.
Your “Hello word...” is most likely in DATA memory in you sample program and from there written to LCD memory. The LCD controller takes it from there and displays it.
You need to find the LCD memory addresses ( it should be in your sample program) and simply write your variable to it from the code itself.
I would suggest you look at the LCD spec to became familiar with how the LCD interacts with the microprocessor. You may find some extra RAM usable as an additional storage for your future programs in the LCD itself.
If you have difficulty finding the LCD address , post your code here.
Cheers Vaclav
' {$STAMP BS2}
' {$PBASIC 2.5}
E PIN 0
RW PIN 2
RS PIN 3
CS PIN 13
CLK PIN 14
DataOutput PIN 15
char VAR Byte ' Character To Send To LCD
inst VAR char ' Induction To Send To LCD
index VAR Word ' Character Pointer
temp VAR Byte ' Temp Variable
adcBits VAR Byte
v VAR Byte
r VAR Byte
v2 VAR Byte
v3 VAR Byte
[ EEPROM Data ]
DATA "Hello, this is the lcd demo" ' Message To Send To LCD
[ Initialization ]
Initialize:
LOW RW ' Set LCD To Write Mode
OUTS = %0000000000000000 ' Set All Output Low
DIRS = %0000000011111111 ' Set I/O Direction
GOSUB Init_Lcd ' Initialize The LCD Display
[ Program Code ]
Main:
DO
GOSUB ADC_Data
GOSUB Calc_Volts
GOSUB Display
GOSUB Init_Lcd
FOR temp = 0 TO 27 ' 28 Characters
IF temp = 15 THEN ' Check For End Of Line
GOSUB Next_Line ' Jump To Next Line
ENDIF
READ temp, char ' Read Next Character From EEPROM
'DO
GOSUB Send_Text ' Send Character To LCD Display
NEXT
LOOP
END
[ Subroutines ]
Init_Lcd:
PAUSE 200
OUTS = %00110000 ' Reset The LCD
PULSOUT E,1 ' Send Command Three Times
PAUSE 10
PULSOUT E,1
PAUSE 10
PULSOUT E,1
PAUSE 10
OUTS = %00100000 ' Set To 4-bit Operation
PULSOUT E,1
Inst = %00101000 ' Function Set (2-Line Mode)
GOSUB Send_Inst
Inst = %00001110 ' Turn On Cursor
GOSUB Send_Inst
Inst = %00000110 ' Set Auto-Increment
GOSUB Send_Inst
Inst = %00000001 ' Clears LCD
GOSUB Send_Inst
Inst = 14 ' Set Cursor To Underline
GOSUB Send_Inst
RETURN
Send_Inst:
LOW RS ' Set Instruction Mode
OUTB = Inst.HIGHNIB ' Send High Nibble
PULSOUT E,1
OUTB = Inst.LOWNIB ' Send Low Nibble
PULSOUT E,1
HIGH RS ' Set LCD Back To Text Mode
RETURN
Send_Text:
OUTB = Char.HIGHNIB ' Send High Nibble
PULSOUT E,1
OUTB = char.LOWNIB ' Send Low Nibble
PULSOUT E,1
PAUSE 100
RETURN
Next_Line:
Inst = 128+64 ' Move Cursor To Line 2
GOSUB Send_Inst
RETURN
ADC_Data:
HIGH CS
LOW CS
LOW CLK
PULSOUT CLK, 210
SHIFTIN DataOutput,CLK,MSBPOST,[adcBits\8]
RETURN
Calc_Volts:
v = 5 * adcBits / 255
r = 5 * adcBits // 255
v2 = 100 * R / 255
RETURN
Display:
DEBUG HOME
DEBUG "8-bit binary value: ", BIN8 adcBits
DEBUG CR, CR, "Decimal value: ", DEC3 adcBits
DEBUG CR, CR, "DVM Reading: "
DEBUG DEC1 v, ".", DEC2 v2, " Volts"
RETURN
Check this post where Chris has a couple of demo programs attached:
http://forums.parallax.com/showthread.php?109408-Writing-variables-to-parallel-LCD.
The LCD RAM address is initialized in your Init_LCD to the base address. You need to read the LCD spec to find that out. But I find it easier to work with offset from the base address. See bellow.
Your Init_LCD is set to auto increment so each time you do Send_text (char) it bumps this RAM address internally in LCD controller .
When you switch to second line in Next_Line you change the LCD RAM by 128+64.
That is relative to current RAM which you still do not know – again need the spec.
To output your V2 variable you could reinitialize the LCD and just do Send_Text with V2 = char.
That will put it in first displayable location on the LCD.
Than you can add offsets ( line plus the “invisible RAM” in LCD ) and put the value wherever.
I would recommend to you to take a look at HD4470 Hitachi LCD document. It will explain the mechanics of LCD controller better that I can.
Have fun moving blinking characters around the LCD.
