FullDuplexSerial issue
I'm trying to run a simple code transmitting serial data from propeller to BS2. I'm not quite sure what i'm missing and/or doing wrong. I'm trying to make sense of the fullduplexserial code itself due to it's popularity but i'm having trouble understanding it due to a large part of it being assembly code. My goal is just to be able to transmit and receive one character at a time. If someone could help in explaining what i'm doing wrong it would be greatly appreciated. i have pin 0 of the propeller connected to pin 1 of the bs2 with a 2.2k in series. attached is my code and below are the results i get on the basic stamp 2 terminal when i let the code run for a little while:
127063126031125062124015123061122030121060120007119059118029117058116014115
John Abshier
simple_serial.init(-1,0,-9600), so i thought the issue was that i didn't have the mode selected in the fullduplexserial initialize set to invert tx and i was right. however i changed the mode to invert tx, by setting mode to 1, and i still get the same output as i mentioned above.
i've also removed the line using dira to set pin 0 to an output. any other ideas?
