Arghh... — Parallax Forums
Arghh...
ajwardajward Posts: 1,130
edited 2011-06-06 17:29 in General Discussion
Taking a break from Bob and Ted, I've been diddling with the PIR sensor. Built an NPN transistor circuit the PIR could use to control a relay that would switch on a video camera and recorder.
An hour an' a half and I couldn't get the 'switch' to work. :frown:
It was then I had a "Doh!" moment.
NPN and PNP transistors from the same manufacturer can look exactly alike! :innocent:
Moving right along....
Amanda
  • Kevin WoodKevin Wood Posts: 1,266
    edited 2011-06-05 14:18
    Yeah, you gotta look at the arrows. :)
    edited 2011-06-05 14:29
    Kevin Wood wrote: »
    Or the part number!
    edited 2011-06-06 13:57
    They all look alike to me.
    I was building some small circuits using pnp and npn's in TO-92
    packages and kept mixing them up. I finally put little red dots on
    top of the npn's in my parts case using nail polish :-)
    Z
  • wjsteelewjsteele Posts: 697
    edited 2011-06-06 14:04
    Ah... your voltage simply wasn't high enough. Crank that baby up and it'll work... if ever so briefly! :-)
    By the way... the nail polish trick is a good one... but I use a red sharpie... it still looks a little funny when a guy goes into a drug store to buy red nail polish.
    Bill
    edited 2011-06-06 14:22
    wjsteele wrote: »
    Hey, this is the new millennium....you could even get away with wearing the polish ;-)
  • schillschill Posts: 741
    edited 2011-06-06 14:23
    Instead of nail polish, I used to use small dots of Testors enamel model paint.
  • ajwardajward Posts: 1,130
    @Holly All I have right now is clear polish and I can see a problem there! :smile:
