Serial Data Garbled
I assembled a basic Propellor circuit on a breadboard. Simple test programs work when loaded into RAM or the EEPROM, but when I try to use the FullDuplexSerial object, instead of outputting the string I give it ("Hello, world!"), it always outputs the same sequence of bytes:
"30 B7 EE DC 87 77 77 6E 03 62 CF 9F 47 EF DC 87 EE C1 FE"
Any advice would be greatly appreciated.
Here's my program for reference:
CON _XINFREQ = 20_000_000 _CLKMODE = XTAL2 + PLL4X rxPin = 31 txPin = 30 baud = 300 OBJ fdx : "FullDuplexSerial" 'serial driver PUB main fdx.start(31,30,0,baud) 'start serial driver fdx.str(string("Hello, world!"))
I use... but I have the standard 5Mhz external clock.
Do you have a 20Mhz external clock?
Maybe.. a high speed clock? Connections? See page 68 in the propeller manual.
Many of those numbers should be ASCII characters. $77 is "w".
It looks like Mike G. has found the main problem.
Welcome to the forums!
Duane
Page 26 of the Propeller Data Sheet specs xtal from 4-8 Mhz, although 10 Mhz has been used and is deemed acceptable.
14.xxx has been used, but I would think 20 Mhz is out of the realm of the PLL.
