VFD driver
bomber
I took apart a microwave and I found a VFD display in it. It is a 16 pin quad digit display with the following sereial and part numbers on it: "NEC No.4 1 - 4 1 FIP4B8C JAPAN". Can you please give me some code and a driver circuit for this VFD? Oh, and can it be done with a BS2 please? thanks in advance to anyone who helps me out!
If this particular module is compatible with the HD44780 standard interface, the best bet is to verify that the 16 pin connector is the same as that standard. Also, you must get the V+ and V- correct as a reversal with mean instant death to the unit. Sure, the 40pin DIP is likely a driver chip, but you may never know exactly what it is. Usually generic ICs start off with a couple of letters that indicate the manufacturer. So the FIP and the LC may help you locate some information, but maybe not the exact chip. FIP is sometimes associated with a company called Finisar. Not sure who LC might be.
