RTC Emulator — Parallax Forums
RTC Emulator
ProcessingData...ProcessingData... Posts: 208
edited 2011-06-02 06:28 in Propeller 1
I have been using the Propeller_RTC_Emulator object in one of my projects.
It seems to me that the current minutes Should be stored in the variable MM in the Propeller_RTC_Emulator_DEMO object.
However, when I print the value to the screen using the vga_text Dec function, it prints "0".
Can anyone explain how to get the minutes value from this object?
    edited 2011-06-01 19:59
    Post the code that you have so far....
  • ProcessingData...ProcessingData... Posts: 208
    edited 2011-06-02 04:31
    Allright, here is the code I have so far:
    ''Propeller Water Detection Demo
    CON
      _clkmode = xtal1 + pll16x
      _xinfreq = 5_000_000
    ''Constants
    rx      =  31
    tx      =  30
    baud    =  115200
    EOT     = 4
    ACK     = 6
    US      = 31
    UniqueID = 130
    ''EEPROM Loader
    UIDAddress    = $7FE0
    EEPROMDevice  = $A0
    EEPROMPin     = 28
    OBJ
    Clock   : "PropellerRTC_Emulator"     '' Real Time Clock Emulator
    ser     : "FullDuplexSerialPlus"      '' Serial COM Object
    vga     : "VGA_Text"                  '' VGA Object
    mem     : "Basic_I2C_Driver"          '' EEPROM Object
    VAR
    ''RTC Variables
      long  TimeString
      byte  SS,MM,HH,AP,DD,MO,YY,LY
      byte  DateStamp[11], TimeStamp[11]
    long UID ' for the UniqueID
    byte lastSync  ' holds the last minute we synced with the computer's RTC
    PUB FULLTEST
    ser.start(rx,tx,0,baud)     '' Start Serial COM
    vga.start(16)               '' Start VGA out
    Clock.Start(@TimeString)    '' Initiate Prop Clock
    waitcnt(clkfreq/10+cnt)     '' wait for VGA to stabilize
    UID := get_UID              '' Get this Chip's Unique ID from EEPROM
    vga.str(string("Unique ID: "))
    vga.dec(UID)
    waitForPing
    getTime
    repeat
      Clock.ParseDateStamp(@DateStamp)
      Clock.ParseTimeStamp(@TimeStamp)
      vga.out(1)                 '' Send the HOME code to the VGA Screen
      vga.str(@DateStamp)       '' Display Date to the VGA terminal
      vga.str(string("  "))
      vga.str(@TimeStamp)       '' Display Time to the VGA terminal
      vga.out(" ")
      vga.dec(TimeString)
      vga.out(" ")
      vga.dec(lastSync)
      check_sync_time
    PUB main | i, flag
    ser.start(rx, tx, 0, baud)
    VGA.Start(16)
    waitcnt(clkfreq+cnt)
    UID := get_UID
    vga.dec(UID)
    repeat
      VGA.dec(waitForPing)
      getTime
      send_mail(@MyEmail,@FrEmail,string("Test"),string("Testing Again. <br> Hello, <b>html</b>"))
    PRI waitForPing | temp
    repeat
      temp := ser.RxCheck           ' check the Input Buffer
      if temp <> -1
        if temp == 5                ' is it a PING?
          ser.rx                    ' remove the EOT (End of Transmission) byte
          ser.tx( ACK )             ' transmit [ACK][UniqueID][EOT]
          ser.dec( UID )
          ser.tx( EOT )
          return true
    return temp
    PRI check_sync_time
    if lastSync+5 < MM
      getTime
    elseif lastSync <> 0 AND MM == 0
      getTime
    PRI getTime | temp, pos
    ''Time request is:  Time[EOT]
    ser.str(string("Time",US))
    custom_str_in(@InputData,EOT)
    ser.tx( ACK )
    ser.tx( EOT )
    '' Start Parsing the Clock Data:
    '' Format is [Year][US][Month][US][Day][US][Hour][US][Minute][US][Second][US][AM/PM][EOT]
    pos := @InputData 'Get a pointer to the TimeString
    Clock.Suspend  'Suspend clock while being set
    '' Pull Year Data
    pos := pullfield(pos,US)
    Clock.SetYear(ser.StrToDec(@Field+2)) ' Pull Last two Digits from Year info
    'Pull Month Data
    Clock.SetMonth(ser.StrToDec(@Field)) 'Set the Month
    'Pull Date Data
    Clock.SetDate(ser.StrToDec(@Field))
    'Pull Hour Data
    Clock.SetHour(ser.StrToDec(@Field))
    'Pull Minute Data
    Clock.SetMin(ser.StrToDec(@Field))
    'Pull Second Data
    Clock.SetSec(ser.StrToDec(@Field))
    'Pull AM/PM Data
    pullfield(pos,0)
    Clock.SetAMPM(ser.StrToDec(@Field))
    Clock.Restart               '' Start Clock after being set
    'save the minute we synced in lastSync
    lastSync := MM
    return True
    PRI pullfield(ptr,chr)| temp
    temp  := @Field
    repeat while byte[ptr] <> chr
      byte[temp++] := byte[ptr++]
    byte[temp]:=0
    return ++ptr
    PRI send_mail(eto,efrom,subj,body)
    '' Supports HTML in message. Format is:
    ' Email[US][SMTP Server][US][SMTP Username][US][SMTP Password][US][To Address][US][From Address][US][Subject][US][Body][US][EOT]
    ser.str(string("Email",US))
    ser.str(@SMTPServ)
    ser.tx(US)
    ser.str(@SMTPUser)
    ser.tx(US)
    ser.str(@SMTPPass)
    ser.tx(US)
    ser.str(eto)
    ser.tx(US)
    ser.str(efrom)
    ser.tx(US)
    ser.str(subj)
    ser.tx(US)
    ser.str(body)
    ser.tx(EOT)
    PRI custom_str_in(ptr,chr) | i,optr
    ''WARNING: This Function *CAN* overwrite Run-Time Memory
    optr := ptr            ' Save original pointer
    repeat
      i := ser.rx          ' RX one byte
      if(i == chr)         ' If matches character, it's the end
        byte[ptr] := 0
        quit
      byte[ptr++] := i     ' otherwise, add it to the string.
    return optr
    PRI get_UID
    vga.str(string("starting EEPROM",13))
    mem.initialize(EEPROMPin)
    return mem.ReadLong(EEPROMPin, EEPROMDevice, UIDAddress)
    DAT
    MyEmail byte "---------@gmail.com",0
    FrEmail byte "---------@gmail.com",0
    SMTPServ byte "smtp.gmail.com",0
    SMTPUser byte "---------@gmail.com",0
    SMTPPass byte "---------",0
    InputData byte "This string will be over-written by the data sent by H2PropGUI. It is Extra Long to prevent data loss.",0
    Field byte "This is for storing info.",0
    &#9484;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9488;
    &#9474;                           TERMS OF USE: MIT License                                  &#9474;
    &#9500;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9508;
    &#9474;Permission is hereby granted, free of charge, to any person obtaining a copy of this  &#9474;
    &#9474;software and associated documentation files (the "Software"), to deal in the Software &#9474;
    &#9474;without restriction, including without limitation the rights to use, copy, modify,    &#9474;
    &#9474;merge, publish, distribute, sublicense, and/or sell copies of the Software, and to    &#9474;
    &#9474;permit persons to whom the Software is furnished to do so, subject to the following   &#9474;
    &#9474;conditions:        &#9474;                                            &#9474;
    &#9474;        &#9474;                                               &#9474;
    &#9474;The above copyright notice and this permission notice shall be included in all copies &#9474;
    &#9474;or substantial portions of the Software.                                              &#9474;
    &#9474;THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED,   &#9474;
    &#9474;INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A         &#9474;
    &#9474;PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT    &#9474;
    &#9474;HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION     &#9474;
    &#9474;OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE        &#9474;
    &#9474;SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.                                &#9474;
    &#9492;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9496;
    Because of the Variable MM always being 0, check_sync_time never runs get_time.
  • RaymanRayman Posts: 16,457
    edited 2011-06-02 05:45
    I've got something called PropTime on my website, maybe that would work better for you....
    It's on this page:
    http://www.rayslogic.com/propeller/Programming/Programming.htm
    under:
    RTC (Real-Time Clock) Services
    "just using the Prop"
    Thanks, Rayman.
    I may use your RTC Object later, as it seems a bit more robust than the RTC_Emulator object, but I have solved the problem.
    I added a function that returns the value of the MM variable inside the RTC Object, and that seems to work fine.
    Thanks for the help!
