What's eating my DAT data?
Working on a little snippit to allow my Propeller to send SMTP authenticated email via a serial link.
For some reason my DAT data seems to get chewed up when monitored with PST.
Data in the wrong places, and partial data. Either the heat is getting to me and I'm doing something silly, or I'm just doing something silly.
A second set of eyes would be appreciated..
Here's the code:
(No, that isn't my actual BASE64 username/password)
Here's the code:
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 OBJ serial : "FullDuplexSerial" 'Standard serial driver DAT eserver byte "8cogs.com",0 efrom byte "jeff@8cogs.com",0 eto byte "jeffledger@gmail.com",0 login byte "amemZreer234ers=",0 pass byte "bWwrGFlreDk=",0 'http://ostermiller.org/calc/encode.html subject byte "message from propeller",0 message byte "Hey my PING sensor just went off!",0 PUB main | range serial.start(31, 30, 0, 115200) repeat 1000000 serial.str(string("ATDT ")) serial.str(eserver) serial.str(string(" 25",13)) repeat 800000 serial.str(string("elho",13)) serial.str(string("auth login",13)) repeat 800000 serial.str(login) serial.tx(13) repeat 800000 serial.str(pass) serial.tx(13) repeat 800000 serial.str(string("MAIL FROM:")) serial.str(efrom) serial.tx(13) repeat 800000 serial.str(string("RCPT TO:")) serial.str(eto) serial.tx(13) repeat 800000 serial.str(string("DATA",13)) serial.str(string("subject:")) serial.str(subject) serial.tx(13) serial.str(message) serial.tx(13) serial.str(string(".",13)) serial.str(string("quit",13))
You're missing some @ in front of your addresses.
serial.str(subject)
serial.str(@subject)
other have *********************
behind them.
edit: Dave beat me to it.
Yeah, I thought it was something simple..
Thanks Guys
OBC
