Really, really, really cheap PC boards!?
I stumbled upon this on the web just now.
http://wa0uwh.blogspot.com/2011/04/boards-received-from-china.html
This guy is getting 1" X 2" 2-sided PC boards delivered for 1.60 USD each.
That seems cheap to me, is it cheap?
Here is his diptrace 3d image of his board.
Here is the actual board he got back from China
Looks pretty good :-)
I went to the site and it seems they have a special that
cuts 2.10 off this price so you would get the boards for
a bit less than 1.40ea and that includes shipping.
The boards are small but you can stuff a lot of sm stuff
on a small 2 sided board like this.
The site says
Green, 2-sided max 5cm x 5cm boards - 10pcs for 9.90
Shipping was reported by the blogger to be 4.00 USD for this package.
http://iteadstudio.com/store/index.php?main_page=product_info&cPath=19_20&products_id=173&zenid=ucavpvkloscvdu57551dmgfhe5
Has anyone done business with these guys before?
he said it took 22 days from order to get these back to the USA
from China...that's a long time but sometimes the wait is worth it
for a bargain. I'm setting someone up in the US to assemble and sell
some projects on ebay...this might be a good board house to use
for that.
The site says
for that.
So 9.90 + 4.00 = 13.90 for 10 little boards.
These boards would be a great match up for these cheap 1.75 USD
Jiffy boxes...should fit the slots well. The complete package of board
and case would be pretty inexpensive for a short run of custom projects.
About 3.50 USD for the case and board plus whatever parts you placed
onto the board. The project I have in mind uses a Tiny85 and several
really cheap parts so the whole thing would be just barely over 6.00 USD.
I think I will try to design a simple board using Diptrace
and order 10 of the little boards.
I'm going to go with a DIP part for the uC and place a low profile
socket on the board... I just think it's better that way so if someone
modifies the program and sets the fuses incorrectly and bricks
it they can just put in a new Tiny85 without having to deal with
removing and replacing a sm part. There should still be plenty
of room on the board even though the DIP parts takes up a lot
more space than the sm one. I found a supplier that sells the 8 pin
sockets for just .02 each. I have an idea for another project that
uses a prop, I would have to go with the sm prop though as a 40 pin
DIP would never fit on these tiny boards.
I've got a design for a little Tiny45/85 prototyping PCB that you can have, if you don't want to make your own. It's 6.54cm x 3.24 cm.
Yes, I know it's easy to recover a tiny85 using an oscillator as
a clock source. It's harder though to recover if you inadvertently
turn off serial programming, then you need high voltage parallel.
I was thinking it would be easier for the end user of the device
to just swap in a new DIP part and be done with it since the 85
is so cheap. The end user might not know enough to do anything
else other than just pry up the uC and stick in a pre-programmed
replacement.
I wouldn't mind seeing your design for a tiny85 board :-)
Perhaps you could post it here or pm it to me.
BTW: I found a china seller on ebay selling USB programmers
for the AVR for just 6.90 and that includes shipping. I'm going to
put a six pin isp block on the board so users can alter the firmware
and direct them to the 6.90 device. It comes with the 6 pin isp cable.
That's a nice simple design :-)
sm 1284p and fit it all on a tiny board this size. You would
have a lot of power for little $ if it would all fit.
I have real problems designing pc boards...it's a sort of
mechanical skill and I'm really bad at that kind of thing.
But I'm sick of having to get someone else to do it for me :-(
I've seen students use cardboard in college. It is probably cheaper to prototype something like that until you get your idea finished. My dad also brought home small plastic paper like sheet you could cut.
http://www.eevblog.com/2011/03/11/eevblog-155-itead-studio-pcb-prototype-goof/
and definitely read the comments.
They obviously don't make the boards themselves. They panelise them, and then send off the Gerbers and drill file to a cheap board supplier, which explains the long delivery period.
I've ordered some of their nRF24L01+ modules. I've already got some similar ones I bought from an Ebay supplier, but their's are cheaper at $4. Another supplier is also selling them for $4, but I thought I'd try Istore, whilst I was on their web site.
I've been dying to get these cheap plastic boxes.
Unfortunately, I'm living in SE Asia, so I can't seem to find any of them.
Any e-stores in China sell those?
I wish I could remember the name of the jobber in China that I used as they are at least proven to me, but I don't. I ordered 25 boards from them and with shipping and all it came to less than $100USD. But this was years ago.
Above all, make sure your jobber has someone that can handle English and that they have software to view and verify the files independently. Both these issues were very helpful to me and shouldn't add to the expense. What they did was to take my submitted files and printed out WYSIWYG pdf files that I have to accept before they went to production. One was Lables and two other were the copper (two sides). They did do a mask file as well, but I didn't look at it.
http://iteadstudio.com/store/index.php?main_page=index&cPath=19_20&zenid=qa08tp07o8bn54mjpo155e5o16
You need to make sure that your design meets these requirements:
http://iteadstudio.com/service/prototyping-pcb-minimum-spacing-limitation/
They should provide that info on their main page, that's why I missed it.
So it seems this thread is all the more important as a way to find good value and good service.
I actually received 11 boards for my $9.90 plus postage (one extra), and they took a total of 11 days to get here from when I placed the order. The board quality looks pretty good: some people have complained about poor drilling tolerances and my vias should really have had a larger annular ring. $0.90 per board and 11 days to make and deliver them is amazing, I can't see how ITead and the factory they use make a profit.
Here is my (mostly) assembled board attached to the FPGA board for testing. It worked OK.
I'll be trying Itead for my next boards.
I've just received an email from ITead saying that my second order has been posted. It was placed on the 28 July, which means it took six days to manufacture the boards. That's actually four working days, the same as for my first order. I might have them in my hands by next Wednesday, if they take the same time to get here. The new board is a wireless sensor prototyping board using a Nordic Semi nRF24L01+ module with a PIC18 controller.
I'll see if I can get another board in the pipeline. A similar wireless sensor board using a Propeller might be fun.
Update (13 August):
The postman tried to deliver my second set of boards yesterday, but I was out and have just collected them from the sorting office. That makes 15 days in total, which is pretty good. I actually received 12 boards.
