At what voltage does the propeller pin go high? — Parallax Forums
idbruceidbruce Posts: 6,197
edited 2011-05-28 22:24 in Propeller 1
Hello Everyone
I am looking for the voltage at which point a pin goes high. I found this in the datasheet, and from this I assume it is anything above 1.6V, but I am unsure.
General purpose I/O Port A. Can source/sink 40 mA each at 3.3 VDC. CMOS level logic with threshold of ≈ ½ VDD or 1.6 VDC @ 3.3 VDC.
Bruce
  • LeonLeon Posts: 7,620
    edited 2011-05-28 08:51
    That's about it. You could check it for yourself.
  • idbruceidbruce Posts: 6,197
    edited 2011-05-28 08:53
    Thanks for the response Leon, I appreciate it.
    Bruce
  • JonnyMacJonnyMac Posts: 9,851
    edited 2011-05-28 09:12
    According to table 8.2 in the data sheet (v1.2) the minimum VIH voltage is 0.6 x Vdd. If you're running at 3.3v this puts the VIH at 1.98v. Obviously, this inconsistency in the data sheet should be addressed by Parallax.
    edited 2011-05-28 10:09
    I've seen the actual threshold as low as 1.42V. It's not consistent from part to part.
    Jon, I don't think the datasheet is inconsistent. The spec that Bruce cites is a nominal value. The spec you cite is the voltage required to guarantee a high reading for all Propeller chips.
    edited 2011-05-28 10:21
    Bruce's quotation has the approximately equal symbol. That's why I said "That's about it."
    edited 2011-05-28 10:44
    Perhaps I'm a fuddy-duddy (sp?) or too conservative in my design approach, but I tend to design to the specs so I don't get caught out by that *one* chip that doesn't behave better than the spec.
    edited 2011-05-28 11:13
    Jon,
    I agree with that sentiment entirely. In the case of the input threshold, it's the reason one of the resistors in the sigma-delta circuit is 150K, instead of both of them being 100K. :)
    Published min and max specs can be misleading, too. When I was new to this game and saw something like, "VIH(min) == 0.6*Vdd and VIL(max) == 0.4*Vdd," I'd think, "Wow! That's a lot of hysteresis!" What such a spec fails to mention is that the two thresholds are not independent of each other and, in fact, that VIH == VIL for any particular pin.
  • PerryPerry Posts: 253
    edited 2011-05-28 13:05
    Jon,
    On the Propeller Backpack manual page 22, you used a bias circuit to establish a voltage for the "line level audio input"
    Is this a good method to find the actual threshold of hi/low inputs?
    Perry
    edited 2011-05-28 13:43
    Perry,
    The voltage divider gets the input close to the logic threshold and helps to establish the input impedance. The feedback resistor in sigma-delta mode finishes the job. If you were to measure the average voltage on the input pin while the sigma-delta is in operation, it would equal the input logic threshold.
    edited 2011-05-28 14:05
    @Phil, JonnyMac, and Leon - Thanks for all your input on this matter and I definitely appreciate it. I have a real hard time trying to read and understand all that technical stuff.
    Bruce
    edited 2011-05-28 14:25
    Bruce, Prop inputs switch state at very nearly exactly VDD / 2, so if you're running the chip at 3v3 then it's going to be a very sharp cutoff at 1.65V. This is a deliberate element of the Prop's design and is used in a number of applications, such as low battery detection and delta-sigma ADC.
    edited 2011-05-28 15:07
    @localroger - Thanks. Yes it is a protoboard and has the 3.3 regulator. I only ask because I have something very strange going on and I am trying to get to the bottom of it. But thank you for your input.
    Bruce
    edited 2011-05-28 15:25
    That's actually not true, as I pointed out above. Thresholds as low as 1.42V at Vdd = 3.3V are not at all uncommon, for example.
    edited 2011-05-28 15:51
    Phil, that's interesting -- didn't see your other post in a quick scan. I know I've seen multiple references to things depending on the VDD/2 cutoff, including delta sigma ADC of course which barely works at all and wouldn't work at all if there was any hysteresis. I'm wondering, if there are variances, if they are pin to pin, chip to chip, or wafer to wafer? And it's kind of odd that there are variances at all, since I'd expect the cutoff to be mediated by electrical field effects that are fairly symmetrical. Perhaps what you are seeing is subtle irregularities in the geometry of the barrier in the FET that receives the outside signal and does the switching?
    edited 2011-05-28 16:20
    The sigma-delta technique is actually pretty good, if you take the variances into consideration and provide for calibration. You're right, though: it would not work at all if there were any hysteresis -- and there isn't any. I don't know where the threshold variances come from, however.
  • davidsaundersdavidsaunders Posts: 1,559
    I have observed that for most DIP-40 Props that i use it is close to 1.3V and for most of the QFP parts it is about 1.5 to 1.6.
