Delta Robot Arm Videos. Ideas for a cool project.
I've already built a robot arm which I've only just begun to explore what it can do. However, if I was looking to build one I might consider one of these instead. Delta robot arms are mechanically simple, but their software kinematics are considerable more complicated than other robots arms. However, for that trade off you can make an arm that is blindingly fast. This is because these arms aren't moving their motors so the inertia of the moving parts is low. This is unlike my revolute arm which I need to slow the arm down to keep reaction torque under control. Here are some examples:
FlexPicker is a commercial version that is scary fast:
Here's a homemade one using motors and an RP5 as a controller:
With a Propeller or BS2, three servos, a relay, an electron magnet, and a whole lot of Lego Technic you could build one on the cheap. I'd put the budget under $100.
How about this Lego effort: http://www.youtube.com/watch?v=7VxCl6w3HS0
Those delta arm robots are geometrically similar to those flying camera rigs on 3 overhead cables.
But Lego servo motors are quite nice as they are continuous rotation with built in quadrature encoders.
Real-time delta robot arm moves at blinding speed, stacking balls on a moving turntable.
Wow, wow, wow. I had to watch it several times to figure out what & how it's moving.
Martin,
Have you seen Brick Link?
Here's their page for light grey 40 tooth gears.
I've purchased stuff from Brick Link when I need a bunch of a particular part.
Duane
Drawing starts at 1:22.
Duane, I didn't see that reply. I've heard of brick link but haven't used them. I may if I ever get around to some of those Technic projects I have in my head.
