need info on problem with BS2p40 and usb to serial downloading.
I have a problem with the usb to serial rs232 adapter when hooked to the BS2p40 on the Professional Development Board. It was working o.k., Last night I was using it and it shut window xp down with a vital error.
It keep saying that there was a problem finding com port 12.
Question : Does the BS2p40 always use com port 12 or can it be changed?
I uninstalled the ftdi driver. Then I tried to reinstall the ftdi driver from the parallax web site down loads site and it would only install a part of the download. It said that some files would not install. I then down loaded the driver from the cd which down loaded o.k. but the BS2p40 keep saying the same problem with com port 12.
I then took out the BS2p40 and replaced it with the BS2 and tried the PDB and the usb to serial adapter and down loaded the hardware,software from the cd that came from parallax and all worked o.k. The BS2 used com port 8.
Does the BS2 always use com port 8?
I changed the usb outputs from one hole to another on my computer the BS2p40 still did not work and the BS2 did work o.k.
What can I try next?
allie
allie
Call tech support and see what they can do for you
Thank you all, for you response and I'm sorry that it took me so long to reply back.
I tried the first two answers to solve the problem with no success. The last answer which was posted I just viewed it now because My computer was being wiped clean. I had the computer with windows XP for approx. 5 or 6 years and had a lot of files on it and when I used it to program the BS2p40 some times it worked and some times not, then I tried the Bs2 and at first it seemed to work but I tried small programs and the Parallax web site said to try some things and it did not solve the problem. I tried changing the BS2 to the supper carrier board all seemed to work o.k. but again small programs.
So I decided to do a full renewal of my computer. I took off windows, then I re-installed it again and every thing worked the way it should.
Thank you for your support, and again I applogize for being so long responding
P.S.
When I was putting windows back on the system I was missing a cd which I had to find and delayed the process.
I Tried to Down load a new FTDI driver from parallax, downloaded o.k. but would not install without errors and that's why I did the new install to windows.
Allie
When all else fails then just re install windows and hope for the best
I am glad you got it working again
Please change the prefix to solved in your first post Thanks
I can't find that little drop down. arrow.
allie
allie
