ViewPort configuration to show lsa-view at a higher zoom?
StefanL38
Hi ViewPort-Experts
I find viewport not very intuitive and I'm definitely over the age of seeing
"find out by try and error" as a funny game.
What do I have to change in the config-code to make the lsa-view showing at a higher zoom
where you can drag the viewed part of shown signal? Or do I have to use the quicksample-object then?
And if yes what has to be changed in the code then?
any kinds of hints and tips are much appreciated
best regards
Stefan
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000 'use standard 5MHz clock
OBJ 'include 2 ViewPort objects:
vp : "Conduit" 'transfers data to/from PC
SqrWave : "SquareWave"
VAR
long irdetectleft
long cntr ' 'binary counter
long nextCycle 'time for next increment
long io 'stores IO port status
long freq 'counter frequency- edited with ViewPort dial
pub demo
vp.monitorina(@io) 'the conduit object will contiually update the io variable with the INA state
optional_configure_viewport 'optionally configure viewport's interface
vp.share(@io,@freq) 'share the <io> and <freq> variables
dira[0]~~
dira[1]~
repeat
SqrWave.Freq(0,0,38000)
waitcnt(clkfreq/1000 + cnt)
irdetectleft := ina[1]
SqrWave.Freq(0,0,0)
pub optional_configure_viewport
vp.config(string("var:io(bits=[cntr[0],0]),freq(unit=kHz,f=x/1000,min=1,max=10)"))
'the io frame is filled by the sampleINA, we're only interested in specific
'bits which we name: 0 make up the cntr, 30 is tx and 31 is rx
'share the freq variable. it has a unit of Hz with range from 1 to 10
vp.config(string("lsa:view=io,timescale=10ms,trigger=io[0]r"))
'configure the lsa graph to display the io variable with 1ms timescale
'and trigger set on bit 18 rising
vp.config(string("edit:freq(default=5,mode=[dial,text,scroll])"))
'configure the edit section to display a dial and text for the freq variable
vp.config(string("start:lsa"))
'start in lsa mode
best regards
Stefan
