Importing code to VSA
My partner and i are currently designing an animatronic sorting hat (from the Harry Potter series) and we have the design down pat. I have no trouble importing the sound files but for some reason I can't find ANYTHING online that references how to actually import code from the Parallax Basic Stamp Editor. We are using Visual Show Automation (VSA). We don't need any hope with the actually coding and such, we simply are at a loss how to get our Parallax code into the VSA. Thanks a bunch for your speedy reply! :thumb:
If you truly want to import PBasic code into the VSA, then you should contact VSA support.
If you are trying to interface a PSC with VSA, see the instructions on the VSA site.
http://www.brookshiresoftware.com/rd_how_sscs_work.htm#parallax
Please do not double post, It is against forum rules.
I hope your project goes smoothly. I'd ditto Mike G's comments. When I looked at the VSA website, there doesn't seem to be any support for PBasic code or for any communication with a Stamp. In that case, your only hope is to get help from VSA support.
If you're using a separate servo controller that is directly supported by VSA, why do you need the Stamp or PBasic?
