Ethernet wires
I have a 12 conductor slip ring ( rotary coupling ) connecting my mother board on top of my robot to the bottom
of my robot were there and ethernet shield.
How many wires are used in ethernet communications? all 8 or less?
Thanks, john
Thanks, john
http://en.wikipedia.org/wiki/Ethernet_over_twisted_pair#Cabling
Nice looking chassis btw. What do you plan for it?
Unpowered: Orang/white, Orange, Green/White, Green. Oranges and greens are swapped on a crossover cable.
POE: Same as above, except Blue/White + Blue = DC+, Brown/WQhite + Brown = DC-
As for the robot im going to run Willow Garges ROS on it to roam around my house.
Follow my build on my Blog
http://assistiverobotics.blogspot.com/
AFA your slip ring issue, could you live with a spiral wire connection that would allow you +/- N turns before it had to unwind? Your software could keep track of the position.
Edit: Just saw your blog... it IS a K2A. Where did you find it?
Ebay of course I been following it for a while and it hasent been selling. So when it got reposted at 750 I offered 550 and got it.
I got it for the base and drive system. The main pieces are cast aluminum The motors both work Freewheeling the motors draw anbout .9 amps so there does'nt appear to be any mechanical isues. The gearbox was leaking but I'm sure the seals are dried out so when the fabrication is done I will take it apart forpaint and cleanning and then replace any seals or bearings.
It came out of Purdue University. I got it at a thrift shop in Fort Wayne Indiana.
