A New type of Switching Regulator - Simple Switcher Power Module LZM12002?
I have been working on several Switching regulator Designs over the years, all which require additional inductors, specific capacitors, fancy PCB Layouts, Heat dissipation requirements etc, and on average, depending on Amperage and Voltage requirements, can cost on average about $10 dollars for the circuit, for small quantities.
All of my designs ( using the Prop) run off batteries (12V SLA) So efficiencies are important. I also require High Currents 1-1.5amps for some of my designs.
One thing I have noticed lately is that some of the specialised capacitors ( TANTALUM, Low ESR etc) required by many switcher circuits have gone up in price and availability is uncertain, even though the regulator itself may be inexpensive.
So In my frustration with sourcing these hard to get capacitor and Inductors , I have just discovered the reasonably NEW type of switching regulator ( modules) , which so far seem to have many benefits..
The one I am interested is the National Semi - LZM12002.
This is an interactive link, flick through the pages for the videos. (I rather watch a video than read through specs!)
http://publications.futureelectronics.com/publication/fd32abfd#/fd32abfd/1
The advantages I can see is that the same PCB LAYOUT can be used for all your designs regardless of Vout or Amperage , The same regulator part can be used for say 5.0 Vout and 3.3 Vout as well, minimising the different parts in a BOM and depending on quantity, better pricing and availability.
You will need to shop around for reasonable prices..
http://www.findchips.com/avail?part=LMZ12002
So far "FutureElectronics" have the best price , around 5-6 dollars, (you have to inquire with them, to get better pricing than what is listed on the website)
Here is a link to where I am getting the price from..
http://www.futureelectronics.com/en/technologies/semiconductors/analog/regulators-reference/switching-regulators/Pages/5171517-LMZ12002TZ-ADJ-NOPB.aspx
Also, With the NEW PROP 2 which requires 1.8 V, and maybe more amperage than the current prop, that this device could be well suited for It, I am about to order one of the evaluation boards.
What do you think?
Are any of you familiar with these type of regulators?
Dave M
What do you think?
Dave M
http://cds.linear.com/docs/Datasheet/3080fb.pdf
Not a bad device, not a bad price, and it looks simple enough to use and keep the costs down.
I had a quick look at the specs, and although it says its "HIGH EFFICIENCY" , the data sheet does not mention the ACTUAL efficiency, being an LDO , I wonder what this could be?
The LZM12002 is about 90% +
Dave M
So with LDO's the efficiency of 12 Vin and 3.3Vout would be around say 25%! , Thats not good for battery power., But Say 12Vin with 5Vout would be about 45%? Is that Correct?
I have used various LDO's and whilst cheaper and easy to use, they all seem to suck up the juice if you know what I mean, So is there any point?
If I use a switcher ( LZM Series) for the 12 to 5 volts, and say the above mentioned LDO ( or similar) for 5 to 3.3 Volts, would the efficiency be about 65%?
In my next design Most of my 3.3 volt regulation is required for an RF Transceiver ( Aerocomm AC4490) it requires a MAX of 1.5 amps, at full duty, So an LDO would not be best for this, would it?
thanks
Dave M
In your case a switch mode regulator is probably best, but for higher efficiency consider going to a lower voltage and/or different type of battery. You can get 6 volt SLA batteries (but wouldn't NiMH have more power per volume?) and the closer the input voltage is to the output the better the efficiency will be.
12V SLA 2.2AH
Dave M
I also made a little batch of small boards that can be used in place of a linear regulator.
Massimo
I'd love to use two of them, but at lower quantities that's > $22 just to get on the board! The footprint and part count (5 resistors/4 caps) are nice though.
Attached is a reference layout for any DipTrace users.
Phil,
Those NiMh Batteries look good, If these can perform the same as SLA's then I may consider this in a future design, the idea of a lower input voltage sounds good as well, i.e more efficient!, but also a lot smaller and faster charging, I have seen some with a 1 year charge life!
Brad,
I am going for 2 X LMZ12002 , one for 12-5v, the other for 5 to 3.3Volt, I can get 100 pieces for about 5 bucks each, this will keep the design Simple and much less reliability on various parts, Can you tell me how they have performed for you< That PCB design you did looks very good!
Regards
Dave M
