IR LEDs for Outdoor Camera
I have an outdoor "security" camera that I use to watch the animals around the bird feeder in my backyard. It's a decent quality one camera with good optics and resolution, however the IR LED's brunt out. They were apparently being over driven by design and while it worked well, they only lasted for about a year or so. I can't find a replacement illuminator board (that's what they call them) that will fit my camera so I bought a bunch of T-1 3/4 LEDs and replaced them (there are 24).
I've done this now with 5 different sets of IR LEDs and none of them are as bright as the original ones, even if I deliberately overdrive them. Does anyone know which IR LED's are typically used in these cameras? The best ones I've found far are the LE-DS158 ones from Sure Electronics (see ebay) -- they were by far the least expensive as well.
For reference the camera is no longer made and the seller says replacement parts are not available for it. It's the model HR49 sold by discount-security-cameras.net.
Katie
Katie
First of all, what field of view do you need to cover with the illumination? IOW, at a 10-foot distance, what subject width fills the image at the zoom setting you plan to use?
Phil,
I should have mentioned that I'm looking for T-1 3/4 LEDs with a coverage angle anywhere from 15 to 30 degrees, a wavelength of 850nm seems to be the best match to the imaging chip.
Just for completeness (but irrelevant) the illuminator board is powered by 12 volts and the circuit is set up as 4 parallel strings of 6 LED's each with a dropping resistor. The LED's I'm using now are speced to run at 60ma and they get pretty much exactly that with a 33 ohm resistor in each of the 4 parallel strings. That works out to be a forward voltage drop of 1.67.
Katie
I don't know how the power output at 60mA (~60mW/sr) compares with what you had before, since I couldn't find a datasheet for the old one online.
Those were among the ones I tried. I read over most of the IR LED T-1 3/4 datasheets on the Mouser and Digikey sites. Almost all are 50-100 milliwatts per seradian but I found that they all stink compared with the orignal ones or the ones from Sure.
I wish that manufacturers would label their LED's like they do almost all other semiconductors, then I'd know what the orignal ones were.
I suppose that I could just buy a couple of illuminator boards for other cameras (they sell them cheap), remove those LED's and give them a try. But then I'll never know the part number
-Katie
http://www.dealextreme.com/p/5mm-ir-led-emitters-20-pack-2399
DX, of course, why didn't I think of them!
I've bought lots of stuff from them over the past few years so I know the waiting game. I wonder if they are any different than the other ones I got from China via Sure for about the same price. I'll have to try then and find out.
Jorge,
I'm really surprised that high brightness red LED's have a significant IR component after passing thru all those filters. Have you been able to compare that to say the IR LED's from DX or any name brand ones?
Thanks for the suggestions,
-Katie
Since you are using it to watch animals at night, some nocturnal animals wont come into your field of view since the IR is visible to some of them and could be blinding them so some sort of filter should be used used. I believe Bobcats are this way along with some mountain lions and bear.
I'm in suburban NY City and have seen under IR illumination: raccoons (every night) , deer, skunks, opossums, hedgehogs, rabbits, turkeys, foxes and coyotes (we've had a bunch of them here recently). None of them seem to mind the IR light at all. I'd be pretty flipped out if I saw a bobcat or mountain lion, but bears are a possibility they've been in the neighborhood before.
Failing all of these suggestions, I could use an IR iilluminator that's not mounted inside the camera housing. This would achieve the goal of seeing well at night, but not the goal of trying to find the original LED's used in this camera or something that fits in the original housing and works as well as the original LEDs.
