18V DC to 9v DC for powering Proto board
Hey everybody!
I'm working on a project with the Easydriver Stepper driver board and I've got it all working except for one thing
I'm using an 18v power supply to power the Easydriver and would like to pull the 6-9v off of that to power the Proto Board too
is that a practical idea and what's the easiest way to step down the 18v to 9v (or so) - I tried a simple voltage divider and even though I got 7.5v it would not power the proto board for some reason
I'm open to any ideas!
However, the parts are a little hard to get hold of. I get the simple switchers from Futurlec but the inductors are not so common - you need 333uH and 1 amp inductors. I have found a source in Australia (Rockby) for $2 ea and they do exist in catalogues from all the big suppliers worldwide (Digikey etc) but you have to search through lots of other parts eg same inductance but much lower current rating.
It may be easier to use a different supply/wallwart/plugpack as these are so cheap nowadays, eg a 9V one.
I started out with a 9v power supply - but I'm getting more torque from the stepper at 18v and this is going to drive my leadscrew on my metal lathe so I think I'll need the torque
Jamie
Duane
I would echo Leon and Drac's recommendation for 'Simple Switchers'.
Even easier, I see from another thread that thes are now available in *module* form!
T o n y
http://forums.parallax.com/showthread.php?131830-A-New-type-of-Switching-Regulator-Simple-Switcher-Power-Module-LZM12002
I'm I missing something?
Duane
LM7805 brings the 24V to 5V - LDO at 3.3 volts for the prop.
You could use diode/s too.
$10 including shipping, input 4-24V, output adjustable 2.5 to 18V, 1.5A, tiny 1 inch square board, all prebuilt.
