Why are there 3 bytes when sampling with an LED on?
captainvip
I am using the colorpal to detect color reflected back. A couple of questions after reading the documentation and implementing it with an MSP430:
1. What is the range of its color sensing capabilities?
2. When do we use Low Sensitivity and High Sensitivity?
3. Why are the bytes outputted from sensing with a color on (lets say RED) 3-digit hexes?
4. How can I take ambient light into consideration?
Thanks and any help will be greatly appreciated,
Vipin
Vipin
1 - Look at the graph on page 2 of the PDF. The sensor range is approximately 400 to 980 nM
2 - Page 10 top paragraph "for low-ambient conditions with external color illumination"
3 - Not sure what you mean. The output is 8 bits as 2 hex digits per color so 6 hex digits for rgb
4 - By following the calibration procedure ambient light is measured and can then be subtracted from the measurements.
Thanks for your reply. So I am guessing that the sensor has to be basically next to the object to detect the light? What i meant by the 3 Hex digits was that when we use the "m" command, it returns me 9 bytes which the document then says shold be read as 3 HEX digits, so for example, if it returns the following bytes,
0x30,0x42,0x46 0x30,0x41,0x34 0x30,0x31,0x32
According to the documentation, I would decode it as by using the ASCII Table:
0x0BF 0x0A4 0x012
Therefore the net result of my sample would be,
0xBFA412.
Now what is the point of the first byte which is usually 0x30(an ASCII '0'), i mean why even bother sending it. The reason I am concerned is because occasionally when the light reflected back is of high intensity, the first byte becomes 0x31/0x32.
Vipin
That's correct. Converted to decimal that would be rgb intesities of 191,164, and 18 respectively.
I could not find any reference to that first byte in the data sheet but it makes sense that that is a status byte. Any intensity over 0x0FF would indicate an intensity above the maximum range. Since the adc used in the ColorPAL is 10 bits it is most likely using the 2 msb's for that hex digit. In other words if that digit is not 0 the light intensity is too high and the reading invalid.
Vip
