Is my BS2 screwed up?
For some reason all but two of my i/o pins flicker on and off repeatedly (noted on debug terminal). example: i have a normally open switch tied into pin 4. when the switch is open it flickers via debug 0 1 repeaedly. but when the switch is close a steady 1 is displayed. my setup: from Vdd--->N.O Sw---->220 ohm resistor---->P4 (from the 220 resistor i also have a 10k pull down resistor to Vss). Not sure whats going on, dont think i cross/short anything. Would appreciate the help if any. Thanks
Also, i took the switch out to see if it was the root of the problem. no dice. I tried different I/O same thing. Then debugged all of the I/O that i wasnt 4 thru 9, and they all were flickering
How does it go if you connect Vdd to the N.C. terminal instead (instead of to N.O.)?
First, take your BS2 out of whatever circuit you have it in and see if it can still be programmed. If so, it's likely still ok.
Always wire with the power off so you can't short anything temporarily, then turn it on after you're done.
If still having problems, post a picture and a schematic then someone will be able to figure out what you are doing better than with the text you posted.
I will give this a try, my other two switches in the circuit are normally close and there still fine
Thanks for your response guys.
