Propeller Tool clipboard error
Hey,
Whenever I try to copy, paste, or any other operation that uses the clipboard in the Propeller Tool, I get an error that says "Cannot open clipboard". I am using Windows 7 Ultimate.
It makes a difference if a copy all text or some lines. I made some experiments but I did not find a regular pattern when in occurs
try to mark and copy some lines, a single line, a single word.
best regards
Stefan
Just seen this for the first time on my Win 7 Pro (SP1) and I'm an Administrator on the PC.
In the code window, Ctrl+A, Ctrl+C always causes this error for code that is longer than about a screen's worth of text. Shorter than this doesn't seem to cause the problem, perhaps a buffer is overflowing in the Prop tool's clipboard handling functions.
That said, the code does seem to make it into the clipboard (for me), I can paste it out into notepad without any missing text.
This bug is a pain in the butt though.
Further investigation...
Deselect everything in the code window and then task switch to some other app, then go back to the Prop tool again and do Ctrl+A, Ctrl+C to copy the whole file to the clipboard... for me that seems to work without crashing. Doing Ctrl+A, Ctrl+C......Ctrl+A, Ctrl+C....Ctrl+A, Ctrl+C in a row repeatedly will soon cause the problem to reappear. Task switching away and back seems to get around it on my machine.
[Rampant Speculation...]
If the Prop tool is using some windows API calls to perform the copying, then perhaps some handle or pointer is out of date. The task switching workaround might suggest this.
