Xbee to Xbee Help
Hello
i have 2 xbees and 2 prop demo boards i have them hooked up and tested but i canyt seem to see why my code i snot working its very simple but its not transmiting.
RX
TX
RX
* AUTO-RECOVER NOTICE: This file was automatically recovered from an earlier Propeller Tool session. *
* ORIGINAL FOLDER: *
* TIME AUTO-SAVED: 20 hours, 13 minutes ago (5/19/2011 11:24:13 PM) *
* OPTIONS: 1) RESTORE THIS FILE by deleting these comments and selecting File -> Save. *
* The existing file in the original folder will be replaced by this one. *
* -- OR -- *
* 2) IGNORE THIS FILE by closing it without saving. *
* This file will be discarded and the original will be left intact. *
RFID Tag Side (remote client)
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
XBEE_DOUT_PIN = 1
XBEE_DIN_PIN = 2
XBEE_MODE = %0000
XBEE_BAUD = 9_600
LED_PIN = 20
LCD_PIN = 3 ' for Parallax 4x20 serial LCD on P0
LCD_BAUD = 19_200
LCD_LINES = 4
obj
xb : "FullDuplexSerial" 'comms to XBee.
xbobj : "XBee_Object_2"
lcd : "debug_lcd"
pst : "Parallax Serial Terminal" ' Serial communication object
var
long recv
byte data[11]
pub go | idx
xbobj.start(XBEE_DOUT_PIN, XBEE_DIN_PIN, XBEE_MODE, XBEE_BAUD) 'start comms to XBee
xbobj.Delay(1000) ' One second delay
if lcd.init(LCD_PIN, LCD_BAUD, LCD_LINES) ' start lcd
lcd.cursor(0) ' cursor off
lcd.backLight(true) ' backlight on (if available)
lcd.custom(0, @Bullet) ' create custom character 0
lcd.cls ' clear the lcd
lcd.str(string("NODE", 13))
lcd.putc(0) ' display custom bullet character
lcd.str(string("Recive", 13))
lcd.putc(0)
lcd.str(string("Transmit", 13))
lcd.putc(0)
'main loop
repeat
ReciveData
pub ReciveData
' pst.strinmax(@data, 1)
' waitcnt(clkfreq/100 + cnt)
' updateLcd(@data)
' pst.str(@data)
xbobj.rxStr(@data)
updateLcd(@data)
pub Delay(mS) ' Delay in milliseconds
waitcnt(clkfreq / 1000 * mS + cnt)
PRI updateLcd(value)
lcd.gotoxy(12, 1)
lcd.dec(value)
lcd.gotoxy(12, 2)
lcd.dec(value)
DAT
Bullet byte $00, $04, $0E, $1F, $0E, $04, $00, $00
TX
Computer Side (host)
CON
XBEE_DOUT_PIN = 1
XBEE_DIN_PIN = 2
XBEE_MODE = %0000
XBEE_BAUD = 9_600
LED_PIN = 20
LCD_BAUD = 19_200
LCD_LINES = 4
obj
lcd : "debug_lcd"
var
long recv
byte data[10]
byte val1
pub go | idx
lcd.putc(0)
lcd.putc(0)
'main loop
repeat
SendData
pub SendData
xbobj.str(string("Hello Xbee"))
waitcnt(clkfreq + cnt)
xbobj.str(string("Hello Again!"))
lcd.gotoxy(12, 1)
lcd.decf(@value, 8) ' print right-justified decimal value
lcd.gotoxy(11, 2)
lcd.ihex(@value, 8) ' print indicated (with $) hex
lcd.gotoxy(7, 3)
lcd.ibin(@value, 12)
DAT
