Need pasm gurus help! Nokia lcd
I have designed a development board (yet another) which uses the 6100 NOKIA LCD (6610 compatible). The problem is that a bunch of LCDs that I bought uses the EPSON controller and some uses the PHILIPS one.
I am using Micah's driver since it's extreamely fast and tiny but she has a bug when switching to PHILIPS where the horizontal axis are reversed. I contacted here but she has no time to fix it
Thank you for taking a look
the PHILIPS LCD DISPLAYS THE DEMO AS:
WHICH IS SWAPPED HORIZONTALLY ...
initPhilips word PCF_SLEEPOUT ' Out of sleep mode word PCF_INVON ' Inversion ON (seems to be required?) word PCF_COLMOD, $103 ' Color mode = 12 bpp word PCF_MADCTL, $1C8 ' Mirror X/Y, reverse RGB word PCF_SETCON, $130 ' Set contrast word 0I'm not saying that's what is causing this but might be a good place to start lookingRegards,
Coley
to
fixed the problem!
I feel frustratingly stupid right now as I played with that value before and could not get it to work.
How did you worked out the $188 (I understand the $1 (data/cmd), but how the $88 ?)
Thank you both. Truly appreciated.
Thanks again.
