Techniques for punching holes in metal for panel-mount components?
I never got around to researching this, but with the creation of this forum, I figured I might as well ask now..
I've noticed that various round panel-mount components such as potentiometers and connectors utilize a flat spot to prevent the component from freely spinning in place - especially if the nut that holds it in place comes a bit loose. How would someone go about doing this on a small scale without manually routing it by hand? Are there attachments for small presses?
http://www.mouser.com/catalog/catalogusd/643/2241.Pdf
The punches you are looking for make "D-shaped" holes.
I swear, this place is faster than Google!
-Mark
http://www.amazon.com/Parts-Express-Nickel-Plated-Nibbling/dp/B0002KRACO still available!
That is what ebay is for! I ended up getting a pretty good deal on some punches there. You can get some very professional results with them! I really like the DB9 punches. Much cleaner than trying to drill, using a nibbling tool, and filing.
http://en.wikipedia.org/wiki/Broaching_%28metalworking%29
If more people used them they would be much cheeper, but most people I have known usualy just make a jig for a router and use that to the same effect. you just need to find a router bit the right size and designed for the material you are cutting, in your case metal. Then make a jig, that fits over your product to be cut, so the smooth non cutting part of the router is guided along by the perticular jig. On some routers the smooth part is on the top, near the collet, on others it is on the bottom of the bit at the tip so design your jig for the type of bit you are using.
I then drill out as much of the material as possible and finish it of using a set of files like this:
http://www.cooperhandtools.com/brands/CF_Files/model_detail.cfm?upc=037103219213
You might also need a set of jewelers files if you have any really small details.
This is good for prototypes and one or two pieces, not something I'd want to do for production.
C.W.
I had two, broke one, and take *real good care* of the one I still have. I carry it with me to and from work in my Personal Tool Box, everyday.
-Matt
You're blowing our feigned online animosity!
People need to believe in something REAL and pick a side. All that's left is you, me, and WWE.
Here's one from Klein Tools that may do the job. It's available at Home Depot, Amazon etc..($25 or less)
"Nibbler Tool
- Cuts soft sheet metal, plastic, soft copper and aluminum, and tubing.
- Ideal for air conditioning and heating installation, automobile work, model making, and sheet metal construction.
"http://www.service.kleintools.com/Tools/PRD/Category/Cutting%20&%20Notching%20Tools%20SHEETMETAL-CUTNOTCH/Product/76011B
I believe this nibbler is similar to the Radio Shack one.
Jameco Electronics: http://www.jameco.com
TOOL,NIBBLING FOR CUTTING,TRIMMING,& NOTCHING SHEET METAL
http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&productId=18810&catalogId=10001&freeText=nibbler&app.products.maxperpage=15&storeId=10001&search_type=jamecoall&ddkey=http:StoreCatalogDrillDownView
Hanlong Industrail Co., LTD
Replacement blade:HT-204 Blade
HT-204
Cuts sheet plate like chassis punch; cuts up to 18 AWG soft metal, 1/16” soft plate. For inside shape, drilled a 3/8” or 9.[FONT=新細明體]5[/FONT][FONT=新細明體]
http://www.hanlong.com.tw/en/type9_6.html
I was taught to avoid using gloves around rotating machinery. This might not apply to a handheld drill but it certainly would apply to using a drill press. The reasoning is this: if you get your finger caught on something rotating, you might lose that little piece of finger, etc. But if your glove gets caught, it can pull your entire hand into the machine, and if the machine is big enough, then it can feed your entire arm into the mess until you're "wrapped around the axle" as one of my bosses was fond of saying. A Yale senior was killed recently on a lathe when her hair got caught in the machine and it pulled her in up to her neck. http://www.nytimes.com/2011/04/14/nyregion/yale-student-dies-in-machine-shop-accident.html
One way to avoid nasty things happening to sheet metal when drilling a hole is to sandwich the sheet metal between two pieces of flat scrap wood. You have to take special care to keep your intended target lined up, etc. but the resulting hole is usually much cleaner than anything you could do in air.
Very true!
I might add one of the situations where people are tempted to wear gloves happens when they are "hogging out" a large hole in a piece of metal like aluminum. When lots of metal turnings/shavings are coming off the workpiece and people want to keep those cuttings from wrapping around the drill bit or milling bit, it's tempting for them to use gloves and manually try to pull the metal shavings away from the cutting bit. Those shavings can get a grip on the gloves and consequently pull glove+hand(+arm,etc.) into the mixmaster of the tool. One way to prevent long shavings from forming is to periodically back up the bit so the shavings break off into smaller pieces, and use a shop vac to continuously suck them away. It's a bit tedious that way but it's better than getting wrapped around the axle.
http://www.youtube.com/watch?v=4xyEJdnW1HM Safety first: check out the "mechanical engineer" at 40 seconds; no tie, and no safety glasses, having an epiphany with his face just inches from the high-speed milling machine! THAT'S how Robert the Robot was invented!
