no stamp found (but debug works)
I am brabd new to basic stamp. we have several items that use the stamps at work but a former employee did a number on them. I am trying to reload the original programs but when i click run it says no stamp found but when i open the debug terminal i can see the program running. any help would be greatly appreciated
It's possible that the board doesn't normally have DTR connected to the ATN pin of the Stamp module to prevent changing the program. Without a schematic or a really good picture of the board, it's impossible to tell.
No stamp found... here we go again, and again... Editorial rant
I believe you have incomplete connection as far as PC (editor) and your circuit with Stamp module on is concerned.
The simplest test is to remove power from the Stamp and have standard COM / DB9 / RS232 connection between PC and Stamp.
If you not get pass "Stamp not found" and do no identify the COM port you have either bad cable or the 6 to 7 short is not there.
The Stamp is doing exctly what it is supposed to do - power on resets and starts running current program which lucily has some DEBUGs in it so you know it is running.
I bet you cannot download new program. .
I would not start fixing this by going to USB now. If you have serial COM cable use it.
Cheers
Vaclav
