Propeller as a Renderer II — Parallax Forums
Vega256Vega256 Posts: 197
edited 2011-05-26 17:12 in Propeller 1
Hey Guys,
In my first 'Renderer' post, I was using the Propeller alongside an Intel 8088 processor. The purpose of the Prop was to read from the VRAM in my circuit and display it as an NTSC video signal. Since then, I have moved to a different processor; the Z80 which will be clocked @ 6MHz. The purpose of the Prop is the same.
Before I waste any time trying to use the Prop with the Z80 as a GPU, I would like to know if it is within the Prop functionality. I will try to use a 3-3-2 RGB color space. Because the Prop works with 32 bits at once, is it still possible for it to generate a color signal with only 8 bits?
    edited 2011-05-17 08:54
    The Prop may work with 32 bits at a time, but its video generator is much more limited. It normally uses a 2 bits per pixel scheme for both video (NTSC/PAL) and VGA with the 4 colors selected from the 4 bytes of a 32 bit word. Read the chapter in the downloadable Hydra Manual on the video generator for details (Chapter 14).
    edited 2011-05-17 08:59
    There are two seperate issues here.
    One is getting pixel data from your CPU memory space. That data can be anything. If you are using bytes, then what you can do graphically all depends on how many of those bytes you can fetch during a scan line.
    Let's say it's 40, which is a perfectly reasonable DMA expectation.
    Those 40 bytes could be big, fat, pixels, where each pixel is one of 256 colors, or they could be lots of little pixels, where each bit of those bytes, 320 bits total, are one of two colors.
    In the Propeller, you would then map the bytes to graphics and colors, and that depends on the scan rate of the display device, and the overall compute power of the Propeller.
    If you plan on just using the reference video circuits, you can get 64 VGA colors mapped to your incoming pixel bytes. Easiest path is to map them 2 bits per pixel, for example, yielding 160 pixels per scan line, with each pixel being one of 4 possible colors, for that byte. Lots of schemes are possible. If you were to use one nibble per pixel, that would be 80 pixels, 16 colors per pixel, with the actual colors being determined in the Propeller.
    Finally, if you don't want to use the reference video circuits, it's possible to drive video in lots of ways, with the trade-offs generally being number of pins, and pixels per line, depending on what is done for color depth.
    Edit: This is a bit out of scope for your post, but I've been reading up on the Apple ][ computer I just got. Plan on interfacing a Propeller with it.
    In the Apple, two clock phases were used to allow video DMA to happen without interrupting the CPU. With a fast RAM, it's highly likely the same could be done with the Z80, allowing byte fetches every cycle, if desired, without slowing the CPU down. What happens is the early phase is used by the video, or the Prop in your case, to get it's byte, leaving the later phase to be done by the CPU, leveraging the fact that the CPU only latches it's data at specific times. Something to think about.
    If you want a reference to the text and timings, I'll post it up here. The Z80 won't align with that, but the overall concept might. I just don't know much about Z80's.
  • davidsaundersdavidsaunders Posts: 1,559
    edited 2011-05-17 09:03
    If you bypass the video renderer altogether, you can bit bang 8BPP with no trouble at 10MHz with one Cog (256 Pixels per line in VGA 640X480@60Hz), or 20MHz with 2 Cogs(512 Pixels per line in VGA 640X480@60Hz), or 40MHz with 4 cogs(1024 Pixels per line in VGA 640X480@60Hz [or direct 800X600]), if you overclock the Prop to 100MHz (using a 6.25MHz Crystal), you can do 25MHz with two cogs (640 Pixels per line in VGA 640X480@60Hz), or 50MHz with 4 COGS (Direct 1024X768). And then you can use what ever color space you want, though I would recommend a 2-2-2-2 color (R-G-B-I ) space for 8BPP.
    Your big trouble will be reading the data in fast enough.
    edited 2011-05-17 09:06
    Isn't RGBI redundant?
    eg: R=2, B=2, G=2, I=0 being equal to R=0, B=0, G=0, I=2??
    edited 2011-05-17 09:10
    Patatohead:
    The RGBI actually does produce more colors, becous you have 4 intensity levels for each combination of RGB values. Yes there are a couple of cases were intensity settings overlap the RGB only variant, though remember there is a two bit DAC for I that is equal to the other three DACs though is driving 3 75 Ohm loads not just one thus the equation changes do to the parallel load.
    edited 2011-05-17 09:15
    That makes perfect sense. Thanks!
  • Vega256Vega256 Posts: 197
    edited 2011-05-17 09:19
    potatohead wrote: »
    Ah, interesting. I will definitely think about that. In the mean, I have quite a bit of reading to do on the Prop's video hardware. I think I have my work cut out for me. In essence, I need to write a driver that will get the Prop to even talk to VRAM and also, I do have a DMA controller coming soon.
    By reference video circuits, do you mean the hardware configuration with already written TV drivers? I could definitely use something to refer to.
    edited 2011-05-17 09:25
    Yes. If you look at your prop tool download, there are some video drivers there. If you go online and download the demo board schematic, those are the "reference" circuits, as most drivers target them.
    Apples used 400ns RAMs, and were able to interleave the video with the CPU at 1Mhz. Z80's use more cycles, so that's probably about the same as a 2 - 3Mhz Z80, in terms of speed and scope. Much faster RAMs are to be had these days. Would be very nice to decouple that DMA from your CPU. That way, the CPU runs at a consistent clock, which may prove useful for a lot of stuff, depending on what you want that computer to look like.
    edited 2011-05-17 09:30
    I forgot to mention that this is going to be interfaced with a television using composite. That info may not change anything; just a heads up.
    edited 2011-05-17 09:46
    That takes me out, In that case ignore my previous statements.
  • ericballericball Posts: 774
    edited 2011-05-17 10:00
    As mentioned by potatohead, your first challenge is going to be getting the graphics bytes from your VRAM into the Propeller's video generator. Just remember that one line of NTSC video is 63.555usec if you plan on reading from VRAM more or less directly to the video generator. If you are instead copying from the VRAM to HUB RAM, remember you only have 32K to store the data in HUB RAM.
    For the video generator itself, I'd recommend reviewing http://propeller.wikispaces.com/Video+Generator
    edited 2011-05-17 10:04
    ericball wrote: »
    Yeah, I just read chapter 14 of the Hydra Manual. Just confirmation, the Video Scale Register does not understand synchronization signals; those are the programmers' job. Is this correct?
    edited 2011-05-17 10:10
    Correct.
    Eric has some nice composite templates you can use. Highly Recommended, if you roll your own video system.
    edited 2011-05-17 10:14
    potatohead wrote: »
    Correct.
    I see that they depend upon either the Demoboard, Hydra, or Hybrid. Can I mod these as well?
    edited 2011-05-17 10:16
    Absolutely you can. That's the beauty of the Propeller. What you would end up doing is running video on whatever spare Propeller pins you have available to you, after interfacing with your Z80 CPU.
    edited 2011-05-17 10:53
    Vega256 wrote: »
    Correct. VSCL counts down the number of PLLA clocks before shifting the Pixel data (PixelClocks) and the number of PLLA clocks before reloading the Pixel & Color data, the VSCL counters, and releasing WAITVID. For composite video synchronization signals are generated via "special" color values (0=sync), for VGA usually two of the bits/pins are tied the the H & V sync lines and again "special" color values change the pins appropriately.
    edited 2011-05-17 11:27
    I am going to start writing this driver soon. I am experienced with C++, x86, and Z80 assembly, so it would be safe to say that I understand higher and lower level programming languages, but it would be convenient if I could write this in predominantly one language, either Spin or Prop ASM. I know that some drivers use both. I presume that I would need the ASM portion in order to load values into the registers. But I am guessing that Prop ASM would be somewhat like other ISAs, where you have the label, source, destination, and optional comments.
    edited 2011-05-17 12:50
    The Propeller instruction set has some other fields, like for conditional execution and for controlling the writing of the instruction results. The Propeller Manual is a good reference for assembly as well as Spin.
    Yes, the heart of video generation is very high speed and precisely timed and this has to be done in assembly. Because of the high throughput needed, some video drivers use more than one cog (processor), typically with the cogs alternating between loading up a line buffer or several scan lines of information, then doing the video generation for what just got loaded. Such cogs have to be precisely synchronized and that's straightforward to do with the Propeller. Best is to look at existing video drivers and how they manage this.
    edited 2011-05-17 13:54
    Vega256 wrote: »
    The purpose of the Prop was to read from the VRAM in my circuit and display it as an NTSC video signal. I will try to use a 3-3-2 RGB color space.
    One item of note - the composite output of the Propeller video generator is based on 6 levels of grey and 16 hues (plus grey). You'd need a 256 entry color lookup table to translate from 3-3-2 RGB to Propeller hue+luma (and the results probably won't be satisfactory).
    edited 2011-05-17 15:52
    From what I am seeing and from what I understand, the TV driver template does not actually output anything. What is this template taking care of? Which portion of the driver do I start building?
    edited 2011-05-17 16:10
    The template outputs color bars on every active video scan line. You would need to build the portion of the driver that handles the active graphics area.
    Have you run the template? It is a complete signal only reference, containing the color bars as something to fill the active graphics area with.
    If you wanted to do a bitmap, as a example, you would setup a pointer to the screen RAM, and loops for a given scan line, and for the active lines in the display.
    I've used that template to build this driver:
    http://forums.parallax.com/entry.php?129-16-Color-Potatotext-8x8-NTSC-TV-Driver
    It is a text display, using two COGs. Two COGs are needed for that one, because of the character density and color lookups needed for 16 color text definitions.
    The primary COG is "the signal cog", and it gets it's data one scan line at a time from "the graphics cog", which looks at the Propeller HUB memory, building a line of graphics in time for the signal cog to render it to the display.
    There are several code examples in that driver that you may find helpful. A scan line based signal COG could be fed graphics from your system that are fetched by a cog or two interacting with the Z80, for example.
    edited 2011-05-17 16:21
    potatohead wrote: »
    I see that at the beginning of the template, there is a case ladder that chooses a hardware interface based on the states of I/O pins 12 and 13. I tied both of those to ground to choose the Demoboard setup. I didn't actually connect this to my TV but I watched all of the pins with my scope and I didn't see anything. No composite signal.
    edited 2011-05-17 16:26
    It's probably better to reproduce the demoboard video circuit, based of the schematic downloadable here:
    http://www.parallax.com/dl/docs/prod/prop/PropDemoDschem.pdf
    ...and remove the case statement, or set the variable before it gets executed to point to the demo board case.
    If that does not work, I would recommend establishing a known good video signal case with the Parallax drivers supplied with the Propeller Tool download. graphics_demo.spin is setup for demoboard by default. Continue with that one, until you get both A signal, and A KNOWN good signal, ideally connected to the display device to verify.
    This is important to do because writing and debugging video drivers is not trivial. Best to have a solid working case, then change one thing at a time to author the desired driver, or make configuration changes.
    edited 2011-05-17 19:34
    Just a heads up... The composite video (we refer to here as TV) requires the first 3 (or 4) prop pins in a 4 pin group. The 4th pin is rarely used. VGA uses a group of 8 pins.
    edited 2011-05-23 15:18
    Regarding drivers,
    How does a high-level driver (a graphics driver for example) interact with the low-level driver (a TV driver for example) that it is meant to work with assuming that the two drivers are two separate spin files? That is, which data bridges the two drivers?
    How could I perform graphics routines without using a higher-level abstraction?
  • AribaAriba Posts: 2,694
    edited 2011-05-23 17:10
    Vega256 wrote: »
    They have a common bitmap buffer in MainRAM. The graphics driver writes to it, the low-level driver reads out the pixels (bits) and form a video signal.
    You pass the address of this common buffer to both objects / drivers.
    You just set bits in the bitmap buffer to define the color of corresponding pixels on the screen.
    Andy
    edited 2011-05-23 18:37
    Vega256 wrote: »
    How does a high-level driver (a graphics driver for example) interact with the low-level driver (a TV driver for example) that it is meant to work with assuming that the two drivers are two separate spin files? That is, which data bridges the two drivers? How could I perform graphics routines without using a higher-level abstraction?
    Typically the PASM driver code is wrapped in a simple SPIN start routine which takes a pointer to a sequence of LONG parameters (that then gets passed along to the PASM code). One or more of the parameters are pointers to the data structures used by the driver. This may be a simple bitmap buffer and a color table, or it might be a pointer to a title array, tile bitmaps and a color table, or a pointer to a character screen buffer and a pointer to the character bitmaps, or a pointer to a sprite table and a pointer to sprite data. It all depends upon the driver, which then depends upon your particular requirements. Higher level functions may be provided by additional SPIN routines in the same object, or a separate SPIN object (e.g. Graphics.spin) which is then paired with an appropriate video driver.
    edited 2011-05-26 06:12
    Hey,
    I have been wondering; in the driver demo, what is the difference in the display_base and the bitmap_base? Are these the pointers to the bitmap buffer and the screen?
    edited 2011-05-26 07:45
    bitmap_base is where the graphics cog will draw to. display_base is where the signal cog gets it's image data from.
    As shipped by default, with the propeller tool, that driver is setup double buffer. One page to draw on, one to display from.
    I've got some good explanation of how that all works, tiles, colors, etc... in my blog here:
    http://forums.parallax.com/entry.php?86-Ripple-Draw
    Single buffer techniques are demonstrated there, as well as some methods to change tiles, colors, etc...
    edited 2011-05-26 14:08
    Is there a way to eliminate the front porch color? I would like to have fullscreen.
