input register (INA) to variable — Parallax Forums
PJAllenPJAllen BannedPosts: 5,065
edited 2011-05-17 08:45 in Propeller 1
I think I'm not understanding the Propeller Manual.
If I have a pushbutton to P8...
dira[8] = 0
byte  btnstatus
btnstatus := ina[8]
If ina[8] is HI then btnstatus = %0000 0001 ?
Or do I have to make btnstatus a long and then btnstatus would be %...0000_0001 0000_0000 ?
    edited 2011-05-16 10:54
    INA[ 8 ] extracts bit #8 to yield a single bit value (0 or 1), so btnstatus is 1 when I/O pin #8 is high.
    In general, INA[ x..y ] extracts a bit field whose high order bit is x and whose low order bit is y. If y > x, then the bits are in reversed order from how they're represented as I/O pins. In all cases, this bit field is right justified in a 32 bit value.
    edited 2011-05-16 11:32
    OK.
    I have:
    dira[15..0] := $00FF (So 15..8 are INs, 7..0 are OUTs)
    Going the btnstatus/alias route resulted in anxiety.
    When I test ina[8] directly, it's as I expect, 0/1, and things move along.
    I should grab a shovel and move everything closer to the computer instead of going back and forth across "the office" as I am.
  • AribaAriba Posts: 2,690
    edited 2011-05-16 13:09
    PJ Allen wrote: »
    ...Or do I have to make btnstatus a long and then btnstatus would be %...0000_0001 0000_0000 ?
    Yes, this is also possible:
    long  btnstatus
    btnstatus := ina
    now every bit in btnstatus represents the corresponding input pin.
    Andy
    edited 2011-05-16 14:20
    OK.
    The objective is for a pushbutton (Jog) to advance a stepper position.
    In buttonchecking2.spin, I test ina[8].
    In buttonchecking3.spin, I test 'btnstatus'.
    PUB buttoncheck
      repeat until ina[8] == 1
      position := position + 1
    versus
    PUB buttoncheck
      repeat until btnstatus == 1
        btnstatus := ina[8]       ' stays stuck w/o
      userpause                   ' dbl-clicks w/o
      btnstatus := ina[8]         ' goes automatic w/o
    Both work, but the second version (buttonchecking3) takes more lines of code or it'll double-pulse.
    Where am I going wrong?
    edited 2011-05-17 08:13
    Some D/L'ers, I see, but no replies.
    That's OK. It's only about Spin and things Propeller, not some supercilious ancillary pretense at association with one.
    Oh well.
    Such is the Propeller Forum Echo Chamber.
    I still found what I was looking for, within me, applying the gray matter, as ever. If anyone's interested, see #9 over here.
  • schillschill Posts: 741
    This is not exactly an answer to your problem, but rather a question about your code. By the way, I'm not sure exactly what's happening, but the problem sounds like a debounce issue (but the delays you've thrown in should be minimizing that, I think).
    Anyway, I was wondering why you didn't write the second version like this:
    PUB buttoncheck
      btnstatus := ina[8]
        btnstatus := ina[8]
      userpause
    The basic structure should be the same as your first version. If you use the following, does it work?
    PUB buttoncheck
      btnstatus := ina[8]
        btnstatus := ina[8]
    I know you say you've already solved your problem (by changing the overall structure of the code) but I'm curious about what the issue here is.
