RS485 network Using the SN75176
Dose anyone have a program that uses the SN75176 in an RS 485 Network between BS2 stamps?
The samples I found for the SN75176 chip only shows data from Master to slave.
The sample I found that showed communication for both directions uses the MAX485 chip.
I need a sample of how the master ask for data and how to setup transmit and receive periods.
Basically, all stations are sitting in "Receive" mode. The Master makes a request by going to "Transmit" and sending a request byte, then returning to "Receive". Based on the contents of the request byte, the Slave goes to "Transmit", sends its data, then goes back to "Receive".
You will use one pin on each Stamp for data and one pin to switch between transmit and Receive.
The best reference for this stuff is Jan Axelson's book "Serial Port Complete" which has several systems described in great detail.
I will see if I can find some code from one of the projects I've done and post it.
Cheers,
