GSed Props?
As I near the completion of the MuAmi, I am looking beyond that to something that I can really enjoy.
My next thought, is to clone the Apple IIgs. In my life there have been 5 computers that I have truly enjoyed, the Apple IIgs, the Commodore 64C, the Atari ST, the Atari TT, and the Amiga. Of these the most enjoyable all a round IS the Apple IIgs, becouse it is the most hackable, the least limited, and the best documented. It does help that WDC is still around so I can still buy 65C816 CPUs.
I ask every one who may be interested in this topic:
What has already been done towards the IIgs HW emulation/replacement with the Propeller? AND What do you think would be the areas best suited to the Propeller as far as IIgs components, and peripherals?
I am looking forward to doing the best Apple IIgs clone yet seen as soon as I finish the MuAmi. The MuAmi has shown me the face of amiga users that I did not know about (and is fairly ugly), unfortunately most of them are proclaiming that they do not want to see another 68K Amiga.
I've a //e platinum waiting on a good power supply. Frankly, I think it would be interesting to:
1. Use our 6502 core to emulate the ][ series.
2. Stuff a prop on a card for the ][ / GS, which is why I got the Apple in the first place, along with having a emulation reference.
http://www.parallax.com/tabid/708/Default.aspx
I stocked up to build it, and just never did. On that one, the Prop is wrapped around the 6502, clocking it, etc... You might find that work very relevant.
For me, the idea of building to some other CPU to clone a retro-computer just doesn't appeal much. Guess that's why I never built the 6502 board. It's much more interesting to have it all on the Prop, even if it takes a coupla props. Programming the Prop is a lot of fun! I can program 6502, 6809 (which is still pretty damn fun), and a few others, but... I don't want to do anything other than glue / interface type stuff on those, because the Prop is where the relevancy and fun is.
That's just me though! Don't let me get in the way. I really was just riffing a little because you said, "Apple", LOL!!
A area of current interest is interfacing. The way I see it, the Apple ][ has a nice 1Mhz bus that's tolerant, and that is extremely well documented, and with the right kinds of signals to learn on. Of all the older 8 bitters, I think it's probably the most open, and I really did a lot on the things back in the day, so the machine itself isn't a significant obstacle.
Apple ][ machines were actually fairly serious computers, limited as they were. First step is to get the Apple running, and some basic software, meaning some DOS and utility disks to load programs via serial, and to use the disk for a coupla minor boot strapping things. Then, build out a prototyping area to do said interfacing. Where it goes from there, who knows? I get to put my collection to use. Scope, temp controlled solder station, etc... Maybe I'll end up with a nice little dev station. I think I'll want to build up a Prop logic analyzer too. The base clock in those things is 14Mhz, and that seems within reach of a Prop.
So I missed the entire "cool" 16 bit era, making money on IBM PC clones, and "playing" on 8 bitters. It wasn't but a year or two, and I had ditched all the 8 bit machines, keeping the PC, and was into IRIX for serious, higher-end computing. I go through cycles, it seems, because I gave away a very solid IRIX collection, much like I did the 8 bitters. For now though, the stuff is cheap, so it can all come full-circle for not a lot of money. Mostly scrounging
Anyway, rock on. Will be interesting to see where you get to on the GS project.
http://www.brielcomputers.com/wordpress/?cat=4
Quote from the page: "Improved video display using Parallax Propeller (works with most TV’s and monitors)"
C.W.
You can use ADTPro, borrow an Apple //E or better Apple II, hook it to the PC through null modem cables, and copy your heart away. Sorry I can not help as my Apple IIGS only has a 3.5 inch 800K floppy drive, a CDR drive, and a 40GB HDD for drives.
Do you really think that a Propeller could emulate a 65816 at 12MHz? I would like to figure out how to get this kind of speed out of a emulated CPU on the Propeller, I have been playing around with trying to get a subset of the 68000 up to speed (so far I have got a 68000 subset running equivalent to a 2MHz real 68000, only accessing hub mem).
I do not have an Apple any more
If you know some who has an Apple II in your area, you may be able to ask them to lend it to you. If I had a 5 1/4" floppy drive for my Apple IIgs I would be glad to do so (unfortunately I do not [never needed one]). The PC can NOT read the Apple Prodos and DOS 3.3 disks. The sectoring is quite non standard, and the controller will not allow you to read the sectoring correctly. This has nothing to do with the drives themselves, it is an issue of the Controllers used in PCs. On the other hand if you have a 68k, or PPC Macintosh or Amiga with a 5 1/4" floppy drive you can read them no problem.
