Popular Science has become just another push for the Arduino.... — Parallax Forums
MicrocontrolledMicrocontrolled Posts: 2,461
edited 2011-05-15 16:34 in General Discussion
With all the talk about the Arduino VS Parallax, I just had to post this.
I got a Popular Science magazine in the mail today, and I went straight to my favorite part, the "How 2.0" section in the back, and after reading about some cool outrageous projects, I found an article written about "getting started with microcontrollers". I knew it was coming, but I had to read it anyway. Sure enough, after building up micros to the top, they say the dreaded word. Arduino. And yes, they loaded it on about what a wonderful microcontroller it is. And I quote; "One of the great things about Arduinos is that you can draw from the wealth of advice. project examples, and other resources published by users worldwide. " Where do we fall short of this?
HOWEVER, he did mention at the end of the article that when the features run slim, there are bigger micros out there that can take a lot more, which is better then anything MAKE has ever said.
My point is, unlike non-consumer electronics magazines, Popular Science reaches out to those who have most likely never heard of microcontrollers before other than the magical chip that makes things work. I know personally that if I had read this Popular Science article 6 years ago (rather then spotting the Basic Stamp in a Radio Shack catalog), I would most likely be basking in Arduina right now, and would probably know a lot less then I do after using nothing but the Prop for 4 years.
  • schillschill Posts: 741
    edited 2011-05-13 15:09
    At this point, I really don't care what people use: Prop, Stamp, PIC, AVR, Arduino, ...
    As long as people are using them. The more people that get involved at some level in making things with this stuff, the better.
    Once someone gets started, if they really get into it they will see the other options. There's no reason to restrict anyone to just one.
    For an article trying to get people going, the last thing you really want to do is throw all the options at them. Let them get their feet wet and then see where it leads them. I haven't seen the article, by the way. I stopped reading Popular Science a long, long time ago (not meant as a negative statement toward Popular Science, just a statement about me).
  • Kevin WoodKevin Wood Posts: 1,266
    edited 2011-05-13 16:41
    If you did know less after using the Arduino (or something else) for 4 years, that would be your fault, not the Arduino's. And if you did learn anything using the Propeller for 4 years, it's because you made the effort to learn, not because the Propeller mystically bestowed knowledge upon you.
    If you really want to learn something here, learn this... the world isn't as black and white as the Arduino/Propeller debate makes it out to be.
    edited 2011-05-13 16:53
    @Kevin Wood: OK, maybe I used too vague a term there. I wouldn't know any less, it would just be that I knew a less practical skillset. I like to think of it as skipping the middleman. Rather then wasting years with "development" processors, I skipped straight to the Propeller, which is a microcontroller you write code for and have a lot of control over. An arduino is actually an AVR with software that lets you write software, so you aren't truly programming a microcontroller, you are programming a microcontroller clone.
  • Mark_TMark_T Posts: 1,981
    edited 2011-05-13 18:41
    The main problem facing the Propeller is the lack of focus in welcoming newcomers and mapping a course through all the confusing different bits of software and boards - the Arduino website is very well designed in this regard.
    The fact the official Propellor software only works on Windows is a BIG turn off for many - there's no justification for this, Arduino got this right. BST is, fortunately, good enough (though I suspect this wasn't the case a few years ago - I get occasional UI freezes ;)
    Having done a few things with the Propeller now I can see the appeal of its powerful hardware and the cog model - in fact I'm having fun programming in assembler (for the first time in years since programming Z80's!). But it won't ever become as mainstream as the Arduino because it has a steeper learning curve and Arduino got there first. I've yet to try the C compilers that are out there (still no gcc/g++ ?).
    Has anyone looked into adding Propeller support in the Arduino framework? A sort of parallel big brother to the AVR chips they currently support? Requires gcc/g++ support I guess.
    edited 2011-05-13 19:18
    I'm sorry, but that just seems like a silly statement to me. The Arduino enviroment isn't that different from any other IDE compiler. You are pretty much saying that anyone who uses an IDE or compiler is not really programming.
    At worst, I guess you could say that the Arduino environment is just a lot of macros.
    edited 2011-05-13 19:24
    Again, you're wrong. Look, sorry to be blunt with you. I know that you like the Propeller, and in all honesty, you've done more with it than I have. That's not the point.
    How is it that you would have developed a less practical skillset? You would need to develop the same skills to use pretty much any microcontroller - a mix of electronics and programming. Some things would have been microcontroller specific, for any micro. FWIW, this is the same practical skillset taught in the WaM kit.
    What exactly is a "development" processor? The Arduino module is no different than a Propeller board, other than which microcontroller is installed. Both contain a microcontroller with supporting circuitry, both are programmed with a supplied development environment, both have access to a collection of software libraries, and neither force you to use those libraries. Each microcontroller can do something that the other can't, which is okay, because that's how they were designed.
    So why all the angst about the Arduino? Why not keep it in the family and start bashing the Basic Stamp & those users instead? Clearly it's not in the same league as the Propeller. It's not even in the same league as the Arduino. I don't know, maybe instead of getting all worked up over the Arduino, people would just accept that some people have different preferences, and leave it at that.
  • edited 2011-05-13 19:30
    It is just business. If you were on the job and your boss told you to use a different processor, would you tell your boss "no"? That is basically how I'm going to look at these debates for now on.
  • LeonLeon Posts: 7,620
    edited 2011-05-14 04:57
    Hobbyists often get fixated on one particular solution. In industry, one uses the best device for the job in hand.
    edited 2011-05-14 05:29
    Never mind, the more people get involved in actually doing and making with Arduino or whatever instead of just dicking around with video games the more the market grows. Hence a bigger market for Parallax and others. After all a percentage of those introduced to electronics and robotics, MCU programming and whatever, via the Arduino will get hooked and find themselves searching for more. Not to mention that a lot of youngsters who become fascinated with such things will be inspired to take it up as a career.
    edited 2011-05-15 12:22
    Yes, people can make much cheaper projects in many cases by using
    a bare AVR without the Arduino board. Arduino is costly overkill for most
    projects.\
    Better to spend 35.00USD and buy an AVR programmer so you can use
    bare chips than spend the same on an Arduino.
    edited 2011-05-15 13:05
    The hand wringing and flagellation is pretty pointless.
    I don't think Parallax was playing wannabe when they developed the prop, Chip had some really neat ideas and made it happen.
    Find ways to make use of what was created, focus on it's strengths, don't sit around and mope because something else is in the spotlight that you think the prop should be in.
    C.W.
  • oldPGMguyoldPGMguy Posts: 25
    edited 2011-05-15 14:48
    its like this....people use whatever mirco they like the best.....no matter if its a parallax product,arduino or a pic....or any other mirco.....some can do things the other can't do.....any fanboys or girls will get in your face with there fav mirco......so life goes on....every mirco has a use....
  • PropabilityPropability Posts: 142
    edited 2011-05-15 15:18
    mirco?
    oldPGMguy wrote: »
  • davidsaundersdavidsaunders Posts: 1,559
    edited 2011-05-15 15:50
    Never say never. Apple (Lisa and Macintosh), Amiga, Atari (ST), All hit before M$-Windoze, were all easier to use, and all had huge user base, yet in the 1990s Windoze took over. The same can easily happen with the MCU market (especially as it is still quite more fragmented than need be).
    mirco?
    sorry micro-controller...is that better
