Wires for my breadboard
Quick Question... I purchased some wires that have pins on the ends to work with my breadboard.
I'd like to make my own custom length wires.. I would prefer that they are solder not crimp. Does anyone know what these pins are called and maybe a source? I'm looking for both male and female.
Eric
Eric
Here is one source, but you can find them at www.jameco.com, www.digikey,com, and www.mouser.com among others.
Male pins: http://www.pololu.com/catalog/product/1931
Female pins: http://www.pololu.com/catalog/product/1930
They have housings as well:
http://www.pololu.com/catalog/category/70
If it's a single pin, in lieu of housings I will often just use some heat shrink tubing.
You can also use the pins from standard 0.1" headers. Just solder your wire to the pin, pull it out of the plastic (usually pretty easy), and add a little heat shrink tubing. The pins referenced above have a smaller diameter and do less damage to wireless breadboards than using header pins.
There are also numerous pins out there with solder cups and no crimping required, but off hand I don't know of any with a diameter appropriate for solderless breadboards. They are usually for things like D-shaped serial and parallel port plugs.
sorry It had to be done
I was surprised to see they considered crimping just fine as a way of connection wires (multi-stranded). Solder after crimping was a big no-no.
I learned a lot from that website. They only allow transparent or translucent heat shrink. Ever since reading that, I've only used transparent heat shrink. It's been really nice to be able to see what's under the heat shrink (which is why NASA uses it).
Duane
Among other things, a bad solder joint can hide other problems (just like opaque heat shrink tubing).
My own reason for crimping then soldering: I do not have a very good crimper. It is single level (same crimp for bare wire and insulation) and my crimps don't end up being very good. The solder saves the day for me. I do this for most small wires and connectors (like the ones linked above).
For larger gauge wire to larger connectors, I only crimp. Getting a good solder joint in a large connector can be difficult - you need a lot of heat since the connector is a big heat sink and you can damage the wire's insulation and wick a lot of solder down along the wire.
For higher power or larger batteries (sub C and up), I use Anderson Powerpole connectors (http://www.powerwerx.com/anderson-powerpoles/powerpole-sets/) and only crimp the wires. But I did splurge and buy a dedicated crimper for those connectors. It makes pretty nice crimps.
I did just order a new crimper to use on the smaller connectors, but I haven't received it yet. Once I've got it, I may stop soldering.
Also, because I am sometimes too lazy to make custom cables (I always seem to need one right now), I do have a decent stockpile of the precrimped wires that www.pololu.com sells. I have a lot of the housings around since I've been using these types of connectors for many years. It's convenient to just grab the colors I want and put the cable together in a few seconds (assuming I'm ok with a 3", 6", or 12" cable - these aren't particularly cheap but the longer ones get really expensive and at that point I usually want a custom length anyway).
My latest batch was from MPJA. I also buy it from Digi-Key.
I use the 3/64" a lot. I often damage the insulation on a wire as I'm soldering. A little bit of this stuff keeps me from worrying about a short from the damaged insulation.
I understand why so many solder and crimp. A good crimper is very expensive and then it's often limited to a few connectors.
Duane
I have tons of Black Heat Shrink but I love the Idea of clear.. I'll have to look into it. You can never have too much spare Heat Shrink!!
Within a single breadboard (or several physically stuck together), I do what you describe. Usually, the wires are custom cut, bent, and routed so they lie flat on the board (assuming I don't have to go over components).
Between boards and connecting to offboard sensors, etc., it's usually (although not always) easier to use stranded wire. Stranded wire is a bit of a pain to plug into breadboards
For solid wires, I cut and bend them myself as you describe.
I do have some of the premade jumpers that you describe around. They came with some breadboards that I got a good deal on (the wires were essentially free). While I have used them - since they're here I might as well - I do not like them as much as the ones I make myself. The main reason (other than length sometimes) is the colors. The premade ones are color-coded based on length and I usually color-code based on use. For example, black = gnd, red = +V (unless multiple voltages are involved), yellow = simple signal "out", white = sensor in, etc. Of course these do vary sometimes.
One of these little suckers is a nice...
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=PTS-10-ND
I bought one about 8 or 9 years ago when I was building a robot that had lots and lots of wiring for sensors, etc.
C.W.
The one important thing to do it test it first. I've seen a couple rare instances that it was tough to strip the ends of the wire. The best wire to use is where you can just strip off the ends with your finger nails. If you can do that the using the stripper will be easy.
I'll use it on the breadboard and also for hard wiring prototypes.
If you want some M/F or F/F jumpers then the ones from Polou are the ones to get....
Robert
Good tip, was not aware of it being corrosive, thanks.
C.W.
That's where most of the wire I used when I was a kid (elementary school) came from. If I took a slightly longer route walking home from school, I could pass a telephone junction box where they were always making changes. I could usually count on picking up lots of useful scraps that were left on the ground.
