Since the Prop can transmit to a television...
... how about to a 27Mhz receiver? Then you could just strap a propeller board to a RC vehicle and control it that way...
Is it worth working on?
Phill made a fantastic sw radio that uses 3 cogs to receive AM
I made a user interface for it you can find here: http://forums.parallax.com/showthread.php?105674-Hook-an-antenna-to-your-Propeller-and-listen-to-the-radio!-%28New-shortwave-prog/page11
You can see the recorded output recievied from a 49Mhz R/C trismitter there.
Perry
The problem with transmitting using the Propeller is that the RF output is really "dirty". You've got three things working against you:
2. The PLLs exhibit significant jitter at most frequencies. This produces unwanted sidebands on either side of your main frequency that can easily cover the entire band.
3. Transmitters used for RC require FCC approval.
Experimenting with RF transmission is fine if the range is only a few feet. But the power output and antenna required for reliable RC operation could land you in hot water with the feds if you try it using the Prop.
It simply can't be done that way. You can filter harmonics with passive components, but you can't get rid of phase jitter with a filter1. The only way I've found to generate clean sine waves with the Prop is by using an external RF oscillator:
1. Let me qualify that: you can get rid of the effects of phase jitter with a very narrow passband filter (e.g. crystal lattice) that eliminates the sidebands. The fundamental may still be of poor quality, though.
that tunes the TV station is meant to be Well shielded. SO its unlikely you will get much in to this box .
If you did you would need a good deal of power and with that amount of power Men in black suits and antennas may come knocking ..
